[RESOLU] Paquet pour EdrawMax - Mise à jour 08/2025
bastien30
07 août 2025 - 12:55
J'avais partagé un paquet pour le logiciel Wondershare EdrawMax mais l'update-package ne fonctionne plus car ils ont changé leur site.
Voici une nouvelle version qui fonctionne.
setup.py :
from setupdevhelpers import *
from os import rename
    appver = control.get_software_version()
    appname = control.name
    install_exe_if_needed(r'edrawmax_%s.exe' % appver, silentflags=r'/VERYSILENT /NORESTART /ACCEPTEULA', min_version=appver, name=appname)
    remove_desktop_shortcut(appname)
def session_setup():
    remove_user_desktop_shortcut(appname)
def update_package():
    url = control.changelog
    latest_version = None
    for col in bs_find_all(url, "h2", "class", "mb-3"):
        if "Windows" in col.text:
            latest_version = col.text.split("Windows V")[1].split(" ")[0]
            break
    if not latest_version:
        error(r'Error fetching latest version from website !')
        # Installers for all versions are availables here: https://support.wondershare.com/how-tos/wondershare/product-download.html
        # It seems all installers contains "full5371" in file name
        latest_url = r'https://download.edrawsoft.com/cbs_down/edraw-max_64bit_%s_full5371.exe' % latest_version
        print(r'Latest version : %s' % latest_version)
        print(r'Latest url : %s' % latest_url)
    if Version(latest_version, 3) > Version(appver, 3):
        installer = r'edrawmax_latest.exe'
        installer_version = r'edrawmax_%s.exe'
        wget(latest_url, installer)
        # Get full version from binary
        bin_version = get_version_from_binary(installer)
        if Version(bin_version, 3) != Version(latest_version, 3):
            error(r'Error : binary version and website version are not the same !')
            # Renaming installer with full version
            os.rename(installer, installer_version % bin_version)
            control.version = '%s-%s'%(bin_version, control.version.split('-')[-1])
            print('Changing version to: %s in WAPT\\control' % control.version)
            remove_outdated_binaries(bin_version)
        print("Already up to date")
control :
package           : xxx-edraw_max
version           : 14.5.4.1333-104
architecture      : x64
section           : base
priority          : optional
categories        : Utilities
maintainer        : XXXX
description       : Edraw Max est un logiciel de diagramme d'affaires et technique en 2D qui aide à créer des diagrammes de flux, des organigrammes, des cartes mentales, des diagrammes de réseau, des plans d'étage, des diagrammes de flux de travail, des graphiques d'affaires et des diagrammes d'ingénierie.
depends           :
conflicts         :
maturity          : PROD
locale            : all
target_os         : windows
min_wapt_version  :
sources           : https://www.edrawsoft.com/download-edrawmax.html
installed_size    :
impacted_process  : EdrawMax,EdrawMaxTray
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : EdrawSoft Co.,Ltd.
keywords          :
licence           : proprietary_restricted
homepage          : https://edrawmax.wondershare.com/
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://edrawmax.wondershare.com/whats-new.html
min_os_version    :
max_os_version    :
italbot
07 août 2025 - 15:49
De notre côté, l'update_package a déjà été modifié et est fonctionnel mais l'installation ne se fait plus silencieusement, c'est pourquoi ce paquet n'est pas à jour sur le store. Si vous avez des informations nous permettant de résoudre ce problème, n'hésitez pas à nous en faire part, merci.
Ingrid
bastien30
07 août 2025 - 16:16
De mon côté l'installation est bien silencieuse, je l'ai déployé sur plusieurs postes aujourd'hui...
Et je n'ai pas changé les paramètres de ligne de commande qui étaient déjà dans l'ancien paquet.
italbot
07 août 2025 - 17:25
Etrange, de notre côté que ce soit en tant qu'admin ou en compte système, l'installation n'aboutit pas car l'installation ne se fait pas silencieusement, une popup apparaît pour demander à confirmer l'installation. Et sur Luti, l'installation tombe en timeout.
Avez-vous réalisé les installations via des paquets wapt sur la console ?
Ingrid
bastien30
07 août 2025 - 17:37
Je viens de valider l'installation du paquet WAPT via la ligne de commande (utilisateur admin) et la console (utilisateur système).
Les deux fonctionnent de manière silencieuse.
Avez vous bien récupéré l'installeur offline complet ? On dirait que vous utilisez l'installeur online à première vue.
Voir la variable latest_url de mon paquet ci-dessus.
italbot
08 août 2025 - 10:22
En effet, nous ne récupérions pas le bon binaire, merci de nous l'avoir remonté :)
Les modifications sont faites, le paquet va pouvoir se mettre à jour.
Bonne journée.
Ingrid
