Test effectuer via la console : package présent dans le dépôt mais avec erreur 666 lors du "Build Upload"
Test effectuer en ligne de commande: package présent dans le dépôt mais avec erreur 666 lors du "wapt-get upload-package"
L'upgrade du client en W11 ne fonctionne pas via le package généré. beaucoup d'erreur:
C:\WindowsUpgrade folder exists, continuing...
Free disk space: 93069709312 bytes
Force Upgrading Windows from version: 10.0.19045 to Windows version: 10.0.26100
Erreur lors de l'installation de ['epl-windows11-24h2']: erreurs dans les paquets [[PackageRequest(package='epl-windows11-24h2',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('epl-windows11-24h2','10.0.26100-115' architecture='x64',maturity='PROD',locale='fr',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Windows\\TEMP\\waptk0hvzdpc\\setup.py", line 121, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4111, in run\n    return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2263, in run\n    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_upgrade_logs"  /compat ignorewarning /dynamicupdate disable\' returned non-zero exit status 3247440384.\nOutput:\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5609, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4548, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4454, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Windows\\TEMP\\waptk0hvzdpc\\setup.py", line 126, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2038, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_upgrade_logs"  /compat ignorewarning /dynamicupdate disable\' returned non-zero exit status 3247440384.\nOutput:\n']]
  File "<string>", line 1662, in run
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 875, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1484, in _run
Exception: Erreur lors de l'installation de ['epl-windows11-24h2']: erreurs dans les paquets [[PackageRequest(package='epl-windows11-24h2',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('epl-windows11-24h2','10.0.26100-115' architecture='x64',maturity='PROD',locale='fr',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Windows\\TEMP\\waptk0hvzdpc\\setup.py", line 121, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4111, in run\n    return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2263, in run\n    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_upgrade_logs"  /compat ignorewarning /dynamicupdate disable\' returned non-zero exit status 3247440384.\nOutput:\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5609, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4548, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4454, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Windows\\TEMP\\waptk0hvzdpc\\setup.py", line 126, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2038, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_upgrade_logs"  /compat ignorewarning /dynamicupdate disable\' returned non-zero exit status 3247440384.\nOutput:\n']]
    self._run()
Un petit plus, Si dans le fichier control la version ne comprend pas la version de l'os en début cela ne fonctionne pas, exemple:
La tentative d'upgrade en W11 ne se lance pas via le package, version inférieur a la version de l'OS.
