[RESOLU] kicad 9 new package
Publié : 25 avr. 2025 - 16:09
Hello dear TIT TEAM and all,
As already discussed, the KiCad software operates based on major versions.
Currently, you have version 7, version 8, and version 9 has been released.
To help you quickly create tis-kicad9, I have:
-Downloaded version 8
-Replaced if "8.0" in data["name"]: with if "9.0" in data["name"]: at line 25 of update_package.py
-Tested and validated the updatepackage function, it's ok
-Tested and validated the installation, it's ok
-For uninstallation, I will report the issue on on their git that their QuietUninstallString command "C:\Program Files\KiCad\9.0\uninstall.exe" /allusers /S does not seem to work.
Could you create this new package for version 9?
Thank you in advance.
