[RESOLU] Paquet pour Sourcetree
Publié : 12 nov. 2024 - 13:44
Si ça peut servir, voici le code du paquet que j'utilise pour le logiciel Sourcetree (https://www.sourcetreeapp.com/) :
Pour Windows :
Pour MacOS :
S'il est possible qu'il soit adopté pour le store TIS ça pourrait être sympa aussi
Merci d'avance.
Pour Windows :
    appver = control.version.split('-',1)[0]
    bin_name = r'SourcetreeEnterpriseSetup_%s.msi' % appver
    parameters = {'ACCEPTEULA':'1'}
    install_msi_if_needed(bin_name, min_version=appver, killbefore=control.impacted_process, properties=parameters)
def update_package():
    url = r'https://www.sourcetreeapp.com/download-archives'
    print(r'Checking latest version...')
    for release in bs_find_all(url, "a"):
        if "Download free" in release:
            continue
        if release["href"].endswith(".msi"):
            url_dl = (release["href"])
            break
    latest_version = url_dl.split("/")[-1].split(".msi")[0].split("_")[-1]
    if Version(latest_version) > Version(appver):
        bin_name = url_dl.split("/")[-1]
        print(r'Latest version is: %s' % latest_version)
        print(r'Downloading latest binary...')
        wget(url_dl, bin_name)
        control.version = '%s-%s'%(latest_version,(control.version.split('-')[-1]))
        print('Changing version to: %s in WAPT\\control' % control.version)
        print(r'Already up to date !')
    # Deleting outdated binaries
    remove_outdated_binaries(latest_version)Code : Tout sélectionner
zip_name_begin = r'Sourcetree'
app_name = r'Sourcetree.app'
    zip_name = glob.glob('%s*.zip' % zip_name_begin)[0]
    run(r'unzip -qq %s %s/*' % (zip_name, app_name))
    install_app(app_name)
    uninstall_app(app_name)
            continue
        if release["href"].endswith(".zip"):
            break
    latest_version = url_dl.split("/")[-1].split(".zip")[0].split("_")[-2]
        # Remove older version ZIP file
        try:
            old_zip_name = glob.glob('%s*.zip' % zip_name_begin)[0]
            if isfile(old_zip_name):
                remove_file(old_zip_name)
        except:
            pass
Merci d'avance.
