[RESOLU] WaptWUA : Certains PC restent en READY avec une erreur de scan
Publié : 12 juil. 2024 - 10:48
Depuis le dernier patch tuesday, j'ai plusieurs 10es de PC dont le scan est en erreur avec le résultat suivant :
Une idée de ce qui ne va pas ?
Cordialement
Tom
Ensure wuauserv Auto Update option is disabled
Download all updates
Scanning with windows updates rules:
 "direct_download":false,
 "default_allow":false,
 "include_potentially_superseded_updates":false,
 "filter":"Type='Software' or Type='Driver'",
 "download_scheduling":"2d",
 "install_scheduling":"2d",
 "install_delay":"20d",
 "postboot_delay":"10m",
 "user_locale":1033
Downloading wsusscn2.cab file from https://srvwapt.MonDomaine/waptwua/wsusscn2.cab
3145728 / 687267824 (0%) (2269 KB/s)
684720128 / 687267824 (100%) (3119 KB/s)
  -> download finished (3127 KB/s)
   Connecting to local update searcher using offline wsusscn2 file...
   Offline Update searcher ready...
Some windows updates have been installed/uninstalled since last scan
Looking for updates with filter: Type='Software' or Type='Driver'
Waiting for WUA search to complete
WUA Search completed !
Done searching
Updates scan done.
re-enabling wuauserv previous state: 0
(-2147319765, 'Élément introuvable.', None, None)
  File "<string>", line 1939, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 254, in _run
    self.result = wua.download_updates(self.force, uuids=self.uuids)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1609, in download_updates
    self.scan_updates_status()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1228, in scan_updates_status
    self.store_cached_update_property(update, 'IsDownloaded', update.IsDownloaded)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 485, in __getattr__
    return self._ApplyTypes_(*args)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 478, in _ApplyTypes_
    self._oleobj_.InvokeTypes(dispid, 0, wFlags, retType, argTypes, *args),
pywintypes.com_error: (-2147319765, 'Élément introuvable.', None, None)
0x8002802b : Élément introuvable.
    self._run()
Cordialement
Tom
