erreur installation group waptdev
Publié : 26 nov. 2015 - 08:33
Je n'arrive pas à installer le group waptdev (testé sous windows 7 64 bits ou windows XP SP3) car les packages tortoisesvn et python27 ne s'installent pas correctement.
Avez-vous une solution?
Cordialement, David
Install python MSI
TypeError: install_msi_if_needed() got an unexpected keyword argument 'properties'
id;description;summary;start_date;logs
14;Installation de kmr-python27 (=2.7.10-4) (task #14);Exception: Erreur lors de l'installation de kmr-python27 (=2.7.10-4) : {'skipped': [], 'additional': [], 'downloads': {'downloaded': [], 'skipped': [u'D:\\wapt\\cache\\kmr-python27_2.7.10-4_x86.wapt'], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'kmr-python27 (=2.7.10-4)', PackageEntry('kmr-python27','2.7.10-4'))], 'errors': [[u'kmr-python27 (=2.7.10-4)', PackageEntry('kmr-python27','2.7.10-4')]], 'unavailable': []};2015-11-26T17:44:21.826000;"Installing kmr-python27
File ""D:\wapt\waptservice\waptservice.py"", line 1982, in run
self.running_task.run()
File ""D:\wapt\waptservice\waptservice.py"", line 1247, in pwrapper
return func(*arg, **kwargs)
File ""D:\wapt\waptservice\waptservice.py"", line 1307, in run
self._run()
File ""D:\wapt\waptservice\waptservice.py"", line 1732, in _run
raise Exception(__('Error during install of {}:{}').format(self.packagename,self.result))
6;Installation de kmr-tortoisesvn (=1.9.26806-10) (task #6);Exception: Erreur lors de l'installation de kmr-tortoisesvn (=1.9.26806-10) : {'skipped': [(u'kmr-vc2012redist', PackageEntry('kmr-vc2012redist','11.0.61030.0-1'))], 'additional': [], 'downloads': {'downloaded': [], 'skipped': [u'D:\\wapt\\cache\\kmr-tortoisesvn_1.9.26806-10_all.wapt'], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'kmr-tortoisesvn (=1.9.26806-10)', PackageEntry('kmr-tortoisesvn','1.9.26806-10'))], 'errors': [[u'kmr-tortoisesvn (=1.9.26806-10)', PackageEntry('kmr-tortoisesvn','1.9.26806-10')]], 'unavailable': []};2015-11-26T17:38:24.528000;"Installing kmr-tortoisesvn
self._run()
Cordialement, David
Install python MSI
self._run()
self._run()
