[RESOLU] Problème de migration 2.2.3 vers 2.5
Publié : 07 févr. 2024 - 11:09
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Postgres 11.2
La migration échoue avec les logs ci-dessous :
Pouvez vous svp m'aider à déboger le problème ?
D'avance merci pour vos réponses.
Release: 10
Codename: buster
Postgres 11.2
2024-02-07 10:52:53,126 INFO Migrating from 2.4.0.0 to 2.4.2.0
File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3144, in execute_sql
cursor.execute(sql, params or ())
psycopg2.errors.UndefinedFunction: function string_to_array(character varying[], unknown) does not exist
LINE 1: ...kages ALTER COLUMN target_os TYPE varchar[] USING string_to_...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
File "<string>", line 1, in <module>
File "/opt/wapt/waptserver/model.py", line 2677, in upgrade_db_structure
wapt_db.execute_sql("ALTER TABLE packages ALTER COLUMN target_os TYPE varchar[] USING string_to_array(target_os,',');")
File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3151, in execute_sql
self.commit()
File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 2917, in __exit__
reraise(new_type, new_type(exc_value, *exc_args), traceback)
File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 190, in reraise
raise value.with_traceback(tb)
peewee.ProgrammingError: function string_to_array(character varying[], unknown) does not exist
