Je me permets de revenir sur le topic précédent concernant ce paquet.
J'ai corrigé la fonction d'audit, une petite erreur d'indentation s'était glissée. Cette erreur faisait que l'audit affichait toujours un WARNING malgré une installation correcte du service.
def audit():
audit_status = "OK"
service_name = "DellClientManagementService"
service_start_mode = get_service_start_mode(service_name)
if service_start_mode in ["Disabled", "Manual"]:
print(f"{service_name} service is stopped and prevents the application from working properly.")
audit_status = "ERROR"
elif not service_installed(service_name):
print(f"{service_name} service does not exist.")
if service_is_running(service_name):
print(f"{service_name} service is working properly.")
print(f"{service_name} service is not running.")
audit_status = "WARNING" # The indent error was here :D
return audit_status
def get_system_manufacturer():
return registry_readstring(HKEY_LOCAL_MACHINE, "SYSTEM\HardwareConfig\Current", "SystemManufacturer") # Ex: Dell Inc.
# Declaring local variables
bin_name = glob.glob("Dell-Command-Update-Windows-Universal-Application_*.EXE")[0]
if "Dell" not in get_system_manufacturer():
print(f"WARNING: {control.name} can only be installed on a Dell System! The installation will be ignored.")
return
# Installing the software
print("Installing: %s" % bin_name)
install_exe_if_needed(
bin_name,
silentflags="/s /factoryinstall",
name="Dell Command | Update",
min_version=control.get_software_version(),
timeout=900,
# Disabling telemetry
registry_set(HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\General", "UserConsentDefault", 0)
registry_set(HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\CFG", "ShowSetupPopup", 0)
# Download updates (notify when ready)
# registry_set(
# HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "AutomationMode", "ScanDownloadNotify"
# registry_set(
# HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "ScheduleMode",
# "Auto"
# Manual updates only
registry_set(
"ManualUpdates"
# Disable notification
registry_set(
HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "DisableNotification", 1
Informations générales :
Serveur WAPT : Debian 11, version 2.4.0.14143, Édition Entreprise
Machine d'administration : Windows 11, version WAPT 2.4.0.14143
