[RESOLU] Paquet WAPT dell-command-update-uwp
SeiyaGame
25 août 2023 - 17:09
J'ai mis à jour ce paquet car une nouvelle version est disponible, c'est la version 5.0.0
J'ai adapté le code pour prendre en compte les changements du site Dell et aussi apporté quelques modifications pour les autres fonctions ( Peut être pas nécessaire ? )
Voici le code du fichier update_package.py:
from setupdevhelpers import *
import re
def update_package():
    # Declaring local variables
    result = False
    proxies = get_proxies()
    if not proxies:
    app_name = control.name
    url = "https://www.dell.com/support/kbdoc/en-us/000177325/dell-command-update"
    # Getting latest download link from official sources
    print("URL used is: %s" % url)
    for bs_search in bs_find_all(url, "a", "target", "_blank", proxies=proxies, timeout=10):  # , headers={"Accept-Language": "en,en-US"} not working
        url_title = (bs_search.string).replace(u'\xa0', u' ')
        if re.search("(?:Windows Universal|Universal Windows) (?:Application|Platform)", url_title):
            download_url = bs_search["href"]
            break
    # Getting latest version from official sources
    print("URL used is: %s" % download_url)
        download_url, "a", "class", "dellmetrics-driverdownloads", proxies=proxies, timeout=10
    ):  # , headers={"Accept-Language": "en,en-US;"} not working
        if "Télécharger" in bs_search.string:
            version = bs_search["href"].split("_")[-2]
            latest_bin = bs_search["href"].split("/")[-1]
            break
    print("Latest %s version is: %s" % (app_name, version))
    print("Download URL is: %s" % download_url)
    # Downloading latest binaries
    if not isfile(latest_bin):
        print("Binary is present: %s" % latest_bin)
        # Checking version from file
        version_from_file = get_version_from_binary(latest_bin)
        # if not version_from_file.startswith(version) and version_from_file != '':
        if Version(version_from_file) != Version(version) and version_from_file != "":
            print("Changing version to the version number of the binary (from: %s to: %s)" % (version, version_from_file))
            os.rename(latest_bin, bin_contains + version_from_file + ".EXE")
            version = version_from_file
            print("Binary file version corresponds to online version")
    if Version(version) > Version(control.get_software_version()):
        print("Software version updated (from: %s to: %s)" % (control.get_software_version(), Version(version)))
        result = True
        print("Software version up-to-date (%s)" % Version(version))
    control.version = "%s-%s" % (Version(version), control.version.split("-", 1)[-1])
    # control.set_software_version(version)
    # Deleting outdated binaries
    # Validating or not update-package-sources
    return result
Voici le code du fichier setup.py :
( Peut être que la modification de la fonction uninstall et audit n'est pas pertinentes )
    bin_name = glob.glob("*Dell-Command-Update-Windows-Universal-Application*.EXE")[0]
    # Installing the software
    print("Installing: %s" % bin_name)
    install_exe_if_needed(
        bin_name,
        silentflags="/s /factoryinstall",
        name="Dell Command | Update for Windows Universal",
        min_version=control.get_software_version(),
        timeout=900,
    # Disabling telemetry
    registry_set(HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\General", "UserConsentDefault", 0)
    registry_set(HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\CFG", "ShowSetupPopup", 0)
    # Download updates (notify when ready)
    registry_set(
        HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "AutomationMode", "ScanDownloadNotify"
    registry_set(
        HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "ScheduleMode",
        "Auto"
    # Manual updates only
    # registry_set(
    #     HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "ScheduleMode",
    #     "ManualUpdates"
    # Disable notification
    # registry_set(
    #     HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "DisableNotification", 1
    # Uninstalling the software
    print("Uninstalling: %s" % control.package)
    softs = installed_softwares('Dell Command | Update')
    for soft in softs:
        msiexec_command = ' '.join(uninstall_cmd(soft['key']))
        break
    run(msiexec_command)
    remove_appx("DellInc.DellCommandUpdate")
def audit():
    service_name = "DellClientManagementService"
    service_start_mode = get_service_start_mode(service_name)
    service_status = service_is_running(service_name)
    if service_start_mode in ["Disabled", "Manual"] and service_status:
        print("The Dell service is stopped and prevents the application from working properly.")
        return "ERROR"
        print("The Dell service is working properly.")
        return "OK"
Flavien.
Informations générales :
Serveur WAPT : Debian 11, version 2.4.0.14143, Édition Entreprise
Machine d'administration : Windows 11, version WAPT 2.4.0.14143
Avatar du membre
jpele
13 sept. 2023 - 17:52
Merci pour votre retour, j'ai modifié le code en ce sens.
Je retravaillé votre audit pour le rendre plus fiable et j'ai intégré la partie du code commenté.
Voici le changelog :
now audit DellClientManagementService service
print that Dell Command Update UWP can only be installed on a Dell System
Pour information l'update_package était corrigé depuis 2 jours sur le dépôt : https://wapt.tranquil.it/wapt-testing
N'hésitez pas à surveiller ce dépôt depuis votre console si vous attendez un paquet.
Jimmy
