[RESOLU] Office 2019 64 bits
Eyji
16 mars 2023 - 11:43
J'ai fait un dépôt pour installer office 2019 en 32 bits et il fonctionne très bien.
Mon problème je voudrais faire le même paquet mais pour une installation office 2019 en 64 bits.
Pourriez-vous me dire l'erreur que j'aurais pu faire.
# https://github.com/YerongAI/Office-Tool
# You should also check for the uninstall string for uninstall_args by using : wapt-get list-registry Office
# raccourcis
RaccourcisDossierProgramm1 = makepath(programfiles32,"Microsoft Office","root","Office16")
softname = "Microsoft Office Professional Plus 2019 - fr-fr"
pgmsoffice = programfiles
uninstall_args = r'scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
    killalltasks('WINWORD.EXE')
    killalltasks('POWERPNT.EXE')
    killalltasks('EXCEL.EXE')
    killalltasks('MSPUB.EXE')
    killalltasks('MSACCESS.EXE')
    killalltasks('INFOPATH.EXE')
    killalltasks('lync.exe')
    killalltasks('ONENOTE.EXE')
    killalltasks('OUTLOOK.EXE')
    killalltasks('ONENOTEM.EXE')
    killalltasks('MSOSYNC.EXE')
    killalltasks('GROOVE.EXE')
    print('installing %s'.format(control.asrequirement()))
    office_installed = installed_softwares(softname)
    cmd = r'"setup.exe" /configure "Configuration-office2019.xml"'
    if not office_installed:
        print('Installing {}'.format(softname))
        if Version(office_installed[0]['version']) < Version(control.version.split('-',1)[0]):
            print('{} already up to date or newer : {}'.format(softname,office_installed[0]['version']))
        error(' {} has been installed but the uninstall key can not be found'.format(softname))
    create_desktop_shortcut(r'Word',target=r'C:\Program Files\Microsoft Office\root\Office16\WINWORD.EXE')
    create_desktop_shortcut(r'Excel',target=r'C:\Program Files\Microsoft Office\root\Office16\EXCEL.EXE')
    create_desktop_shortcut(r'Outlook',target=r'C:\Program Files\Microsoft Office\root\Office16\OUTLOOK.EXE')
    create_desktop_shortcut(r'PowerPoint',target=r'C:\Program Files\Microsoft Office\root\Office16\POWERPNT.EXE')
Fichier de configuration XML
<Configuration>
  <Add OfficeClientEdition="64" Channel="PerpetualVL2019">
    <Product ID="ProPlus2019Volume">
      <Language ID="fr-fr" />
    </Product>
  </Add>
  <RemoveMSI>
    <IgnoreProduct ID="VisPro" />
    <IgnoreProduct ID="VisStd" />
  </RemoveMSI>
  <Display Level="None" AcceptEULA="TRUE" />
</Configuration>
Merci d'avance.
16 mars 2023 - 14:06
Bonjour Mehdi,
version wapt, version os server/client, edition, etc, (cf. forum rules above).
C'est quoi le message d'erreur à la base?
Eyji
16 mars 2023 - 14:36
Je suis sur une version 2.3.0.13516, serveur DEBIAN 10.9 / client Windows 10 LTSC 21H2.
Voici mon message d'erreur.
  File "C:\Program Files (x86)\wapt\common.py", line 4001, in install_wapt
    setup = import_setup(setup_filename)
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1520, in import_setup
  File "imp.py", line 171, in load_source
  File "<frozen importlib._bootstrap>", line 702, in _load
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 843, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "C:\Windows\TEMP\waptom4sqfqv\setup.py", line 8, in <module>
NameError: name 'makepath' is not defined
Mehdi
16 mars 2023 - 18:03
rebonjour Mehdi,
il faut garder les deux lignes suivantes en entête du paquet :
# -*- coding: UTF-8 -*-
makepath est une fonction wapt/setuphelpers et pas une fonction native python.
Eyji
17 mars 2023 - 11:07
Je suis vraiment désolé de vous avoir dérangé juste pour ça j'avais pas fait attention que je n'avais pas tout copier :?
Merci pour votre rapidité.
Bonne journée,
Mehdi
23 mars 2023 - 16:41
pas de soucis Medhi, merci pour le retour!
