Echec Scan WindowsUpdate
t.heroult
21 févr. 2023 - 15:55
Sur un serveur, lorsque je lance le scan des màj, j'obtiens cette erreur au bout d'une minute :
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download":false,
 "default_allow":false,
 "include_potentially_superseded_updates":false,
 "filter":"Type='Software' or Type='Driver'",
 "download_scheduling":"None",
 "install_scheduling":"None",
 "install_delay":"None",
 "postboot_delay":"10m"
Looking for updates with filter: Type='Software' or Type='Driver'
   Connecting to local update searcher using offline wsusscn2 file...
re-enabling wuauserv previous state: 2
(-2147352567, 'Une exception s’est produite.', (0, None, None, None, 0, -2145124303), None)
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1907, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 710, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 216, in _run
    self.result = wua.scan_updates_status(self.force)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 914, in scan_updates_status
    for update in self.updates():
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 822, in updates
    search_job = self.update_searcher().BeginSearch(self.params.filter, scb_interface, None)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 784, in update_searcher
    self._update_service = self.update_service_manager().AddScanPackageService("Offline Sync Service", self.wsusscn2)
  File "C:\Windows\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateServiceManager2.py", line 36, in AddScanPackageService
    ret = self._oleobj_.InvokeTypes(1610743814, LCID, 1, (9, 0), ((8, 1), (8, 1), (3, 49)),serviceName
pywintypes.com_error: (-2147352567, 'Une exception s’est produite.', (0, None, None, None, 0, -2145124303), None)
0x80020009 (Une exception s’est produite.): 0x80240031 ((unable to get meaning for error code 0x80240031))
    self._run()
Une idée ?
Tom
Server : WAPT Entreprise 2.6.1.17786 sur Debian
Consoles : Windows 10 & 11
Parc : Windows
21 févr. 2023 - 18:17
Bonsoir,
L'erreur correspondrait à "One or more Windows Update components in the registry may become corrupted, damaged, or missing."
la commande
sfc /scannow
lancée dans un cmd administrateur avec élévation de privilèges peut contribuer à résoudre le problème.
24 févr. 2023 - 14:21
Bonjour Thomas,
est ce que le sfc /scannow a résolu le soucis sur la machine? (histoire de pouvoir clôturer le topic)
t.heroult
02 mars 2023 - 14:29
Je ne peux essayer pour le moment, le serveur est en attente de reboot et le sfc /scannow attend que le redémarrage soit fait pour être exécuter.
Ca peut prendre un moment...
Parc : Windows
