Installation paquet Microsoft office 2021
khunio
22 janv. 2023 - 03:34
j'aimerai avoir de l'aide de l'installation du paquet de Microsoft Office 2021 qui est assez différent de l'installation du paquet de Microsoft Office 2016.
Cordialement.
Eyji
27 janv. 2023 - 11:13
J'ai le même problème pour l’installation du paquet office 2021...
r"""
    def killsoft():
      for soft in ('WINWORD.EXE','POWERPNT.EXE','EXCEL.exe','MSPUB.EXE','MSACCESS.EXE','INFOPATH.EXE','lync.exe','ONENOTE.EXE','OUTLOOK.EXE','ONENOTEM.EXE','MSOSYNC.EXE','GROOVE.EXE'):
        if isrunning(soft):
           print ("closing %s" % soft)
           killalltasks(soft)
    print('ProPlus2021Volume')
    cmd = r'setup.exe /configure "configuration-Office2021.xml"'
    killsoft()
Et j'ai ça comme erreur..
Ligne de Commande : install "C:\waptdev\wapt-microsoft-office-2021_16.0.14326.20152_Windows_PROD\WAPT\.."
Installing WAPT files C:\waptdev\wapt-microsoft-office-2021_16.0.14326.20152_Windows_PROD
ProPlus2021Volume
2023-01-27 11:09:21,938 CRITICAL Fatal error in install script: CalledProcessErrorOutput: Command 'setup.exe /configure "configuration-Office2021.xml"' returned non-zero exit status 1603.
Output::
  File "C:\Program Files (x86)\wapt\common.py", line 4074, in install_wapt
  File "C:\waptdev\wapt-microsoft-office-2021_16.0.14326.20152_Windows_PROD\setup.py", line 21, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3851, in run
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2112, in run
waptutils.CalledProcessErrorOutput: Command 'setup.exe /configure "configuration-Office2021.xml"' returned non-zero exit status 1603.
Output:
FATAL ERROR : CalledProcessErrorOutput: Command 'setup.exe /configure "configuration-Office2021.xml"' returned non-zero exit status 1603.
Output:
Exit code:  3
Voici mon fichier xml...
<Configuration ID="d662e083-01aa-4b49-8d05-2c41c49e458f">
  <Add OfficeClientEdition="64" Channel="PerpetualVL2021">
    <Product ID="ProPlus2021Volume">
      <Language ID="fr-fr" />
      <ExcludeApp ID="Lync" />
    </Product>
  </Add>
  <Property Name="SharedComputerLicensing" Value="0" />
  <Property Name="FORCEAPPSHUTDOWN" Value="TRUE" />
  <Property Name="DeviceBasedLicensing" Value="0" />
  <Property Name="SCLCacheOverride" Value="0" />
  <Property Name="AUTOACTIVATE" Value="1" />
  <Updates Enabled="FALSE" />
  <RemoveMSI>
    <IgnoreProduct ID="InfoPath" />
    <IgnoreProduct ID="InfoPathR" />
    <IgnoreProduct ID="PrjPro" />
    <IgnoreProduct ID="PrjStd" />
    <IgnoreProduct ID="SharePointDesigner" />
    <IgnoreProduct ID="VisPro" />
    <IgnoreProduct ID="VisStd" />
  </RemoveMSI>
  <Display Level="None" AcceptEULA="TRUE" />
</Configuration>
gaelds
12 juin 2023 - 11:46
EDIT: j'ai fini par réussir à créer mon paquet Office2021 en utilisant tis-microsoft-office-template
