[RESOLU] WUA : Erreur string indices must be integers
Publié : 01 sept. 2022 - 11:25
J'ai cette erreur sur quelques machines au moment du scan.
Pouvez-vous m'aiguiller ?
Tom
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download": false,
 "default_allow": false,
 "include_potentially_superseded_updates": false,
 "filter": "Type='Software' or Type='Driver'",
 "download_scheduling": "5d",
 "install_scheduling": "12h",
 "install_delay": "2d",
 "postboot_delay": "10m"
   Connecting to local update searcher using offline wsusscn2 file...
   Offline Update searcher ready...
Looking for updates with filter: Type='Software' or Type='Driver'
Waiting for WUA search to complete
WUA Search completed !
Done searching
Updates scan done.
Writing status in local wapt DB
re-enabling wuauserv previous state: 0
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1894, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 692, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 291, in _run
    self.result = wua.install_updates(self.force, uuids=self.uuids)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1335, in install_updates
    self.scan_updates_status()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1024, in scan_updates_status
    if not u['HotFixID'] in dict_id_description:
TypeError: string indices must be integers
    self._run()
Tom
