Paquet clé de registre
* Préciser version de WAPT installée ( 1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AINSI QUE l'édition Enterprise / Discovery
eliottiph
06 mai 2022 - 17:01
- Version de WAPT installée : WAPT 2.2.11899
- OS du serveur : Debian 10
- Serveur DHCP : Win19 Server
- OS de la machine d'administration/création des paquets : Windows Server 19
J'essaye de créer un paquet pour installer une clé de registre.
from setuphelpers_windows import *
        pass
        pass
def session_setup():
    registry_set(HKEY_CURRENT_USER, r"SOFTWARE/Microsoft/Internet Explorer/BrowserEmulation/ClearableListData", 'UserFilter', '41,1f,00,00,53,08,ad,ba,03,00,00,00,8c,00,00,00,01,00,00,00,03,00,00,00,0c,00,00,00,61,b0,8c,da,26,49,d6,01,01,00,00,00,0f,00,31,00,36,00,34,00,2e,00,31,00,33,00,38,00,2e,00,32,00,34,00,32,00,2e,00,31,00,39,00,37,00,0c,00,00,00,80,a6,a4,f5,fb,55,d6,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,36,00,37,00,0c,00,00,00,07,6d,09,61,c6,ae,d7,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,35,00,38,00', type=winreg.REG_BINARY)
    print ('Installation de la clé de registre GCE')
Voici l'erreur :
  File "C:\Program Files (x86)\wapt\waptpackage.py", line 2974, in call_setup_hook
    hookdata = hook_func()
  File "c:\waptdev\keyregistry-GCE_0_PROD-wapt\setup.py", line 12, in session_setup
    registry_set(HKEY_CURRENT_USER, r"SOFTWARE/Microsoft/Internet Explorer/BrowserEmulation/ClearableListData", 'UserFilter', '41 1f 00 00 53 08 ad ba 03 00 00 00 8c 00 00 00 01 00 00 00 03 00 00 00 0c 00 00 00 61 b0 8c da 26 49 d6 01 01 00 00 00 0f 00 31 00 36 00 34 00 2e 00 31 00 33 00 38 00 2e 00 32 00 34 00 32 00 2e 00 31 00 39 00 37 00 0c 00 00 00 80 a6 a4 f5 fb 55 d6 01 01 00 00 00 0b 00 31 00 30 00 2e 00 31 00 34 00 37 00 2e 00 30 00 2e 00 36 00 37 00 0c 00 00 00 07 6d 09 61 c6 ae d7 01 01 00 00 00 0b 00 31 00 30 00 2e 00 31 00 34 00 37 00 2e 00 30 00 2e 00 35 00 38 00', type=winreg.REG_BINARY)
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3825, in registry_set
    return reg_setvalue(key, keyname, value, type=type)
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 447, in reg_setvalue
    return winreg.SetValueEx(key, name, 0, type, value)
TypeError: Objects of type 'str' can not be used as binary registry values
Merci d'avance.
Dernière modification par eliottiph le 11 mai 2022 - 13:29, modifié 1 fois.
06 mai 2022 - 17:37
Il faut décoder la chaîne hexa pour la transformer en données binaires.
Pour cela, il faut importer le module "binascii" et utiliser la fonction unhexlify je pense.
import binascii
        pass
        pass
    bindata = binascii.unhexlify('41,1f,00,00,53,08,ad,ba,03,00,00,00,8c,00,00,00,01,00,00,00,03,00,00,00,0c,00,00,00,61,b0,8c,da,26,49,d6,01,01,00,00,00,0f,00,31,00,36,00,34,00,2e,00,31,00,33,00,38,00,2e,00,32,00,34,00,32,00,2e,00,31,00,39,00,37,00,0c,00,00,00,80,a6,a4,f5,fb,55,d6,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,36,00,37,00,0c,00,00,00,07,6d,09,61,c6,ae,d7,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,35,00,38,00'.replace(',',''))
    registry_set(HKEY_CURRENT_USER, r"SOFTWARE/Microsoft/Internet Explorer/BrowserEmulation/ClearableListData", 'UserFilter',bindata  , type=winreg.REG_BINARY)
eliottiph
10 mai 2022 - 15:53
Bonjour htouvet,
Merci beaucoup pour l'aide, :)
En revanche, la machine ciblé installe la clé de registre seulement sur son compte master local.
Existe t-il une solution pour palier à cela et installer la clé de registre sur toutes les sessions ?
Merci d'avance.
Répondre
