Super ! On évolue.
Ca marche toujours pas mais ça avance. J'ai pu rajouter le CNAME à la keytab en forçant le service
Merci pour le conseil sur la purge, je pense que ça me bloquait...
En mode debug...
wapt-get register -l debug
Current loglevel : DEBUG
2020-06-23 16:41:55,690 DEBUG Default encoding : ascii
2020-06-23 16:41:55,691 DEBUG Setting encoding for stdout and stderr to cp850
2020-06-23 16:41:55,697 DEBUG Python path ['C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\python27.zip', 'C:\\Program Files (x86)\\wapt\\DLLs', 'C:\\Program Files (x86)\\wapt\\lib', 'C:\\Program Files (x86)\\wapt\\lib\\plat-win', 'C:\\Program Files (x86)\\wapt\\lib\\lib-tk', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\pywin32-227-py2.7-win32.egg', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\win32', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\win32\\lib', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\Pythonwin']
2020-06-23 16:41:55,698 INFO Using local waptservice configuration C:\Program Files (x86)\wapt\wapt-get.ini
2020-06-23 16:41:55,698 DEBUG Config file: C:\Program Files (x86)\wapt\wapt-get.ini
2020-06-23 16:41:55,711 DEBUG Thread 8048 is connecting to wapt db
2020-06-23 16:41:55,799 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\4C4C4544-0051-4C10-804C-B7C04F443033.pem for repo global auth
2020-06-23 16:41:55,841 DEBUG Thread 8048 is connecting to wapt db
2020-06-23 16:41:55,842 DEBUG DB Start transaction
2020-06-23 16:41:55,842 DEBUG DB commit
2020-06-23 16:41:55,934 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\4C4C4544-0051-4C10-804C-B7C04F443033.pem for repo wapt auth
2020-06-23 16:41:55,973 INFO Main repository: https://wapt.domain.public/wapt
2020-06-23 16:41:56,112 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\4C4C4544-0051-4C10-804C-B7C04F443033.pem for repo wapt-host auth
2020-06-23 16:41:56,153 INFO User Groups:[]
2020-06-23 16:41:56,153 DEBUG WAPT base directory : C:\Program Files (x86)\wapt
2020-06-23 16:41:56,154 DEBUG Package cache dir : C:\Program Files (x86)\wapt\cache
2020-06-23 16:41:56,154 DEBUG WAPT DB Structure version;: 20200415
Registering host against server: https://wapt.domain.public
2020-06-23 16:41:56,154 DEBUG DB Start transaction
2020-06-23 16:41:56,158 DEBUG DB commit
2020-06-23 16:41:56,181 DEBUG DB Start transaction
2020-06-23 16:41:56,183 DEBUG DB commit
2020-06-23 16:41:56,186 DEBUG DB Start transaction
2020-06-23 16:41:56,187 DEBUG DB commit
2020-06-23 16:41:56,467 DEBUG Unable to GET username from SID S-1-5-21-105001 : (1332, 'LookupAccountSid', 'Le mappage entre les noms de compte et les ID de s\xe9curit\xe9 n\x92a pas \xe9t\xe9 effectu\xe9.'), using profile directory instead
2020-06-23 16:41:56,470 DEBUG Unable to GET username from SID S-1-5-21-105001 : (1332, 'LookupAccountSid', 'Le mappage entre les noms de compte et les ID de s\xe9curit\xe9 n\x92a pas \xe9t\xe9 effectu\xe9.'), using profile directory instead
2020-06-23 16:41:56,525 DEBUG DB Start transaction
2020-06-23 16:41:56,529 DEBUG DB commit
2020-06-23 16:41:56,535 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,538 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,539 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,540 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,543 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,548 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,552 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,555 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,559 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,565 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,569 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,573 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,581 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,586 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,592 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,598 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,605 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,612 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,619 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,628 DEBUG Stores cert chain check in cache
2020-06-23 16:41:56,740 INFO Run "dmidecode -q"
2020-06-23 16:41:56,749 INFO dmidecode -q command returns code 0
        System Power Controls
2020-06-23 16:41:59,147 DEBUG Loading ssl context with cert C:\Program Files (x86)\wapt\private\4C4C4544-0051-4C10-804C-B7C04F443033.crt and key C:\Program Files (x86)\wapt\private\4C4C4544-0051-4C10-804C-B7C04F443033.pem
2020-06-23 16:41:59,153 DEBUG Starting new HTTPS connection (1): wapt.domain.public:443
2020-06-23 16:41:59,171 DEBUG https://wapt.domain.public:443 "POST /add_host_kerberos HTTP/1.1" 401 195
2020-06-23 16:41:59,174 DEBUG https://wapt.domain.public:443 "POST /add_host_kerberos HTTP/1.1" 401 195
2020-06-23 16:41:59,174 DEBUG handle_401(): Handling: 401
2020-06-23 16:41:59,177 DEBUG authenticate_user(): Authorization header: Negotiate YIIGSAYJKoZIhvcSAQICAQBuggY3MIIGM6ADAgEFoQMCAQ6iBwMFACAAAACjggRuYYIEajCCBGagAwIBBaEJGwd
GsVFs2HdSnmLrsr6REVVsoU2vQVrDnDVWBWgJsaR+2XBMCdNJeZmz9rv3PHAilS3jp2/UTElocXczY3f4gSnqLhWcaJSgRSJUruPF+f9KdTy41CLb3f7gVlzvoFv4sQtGaVQyurHII3vf5Ng1uzFiVlAq8/cxU30M7ivZEwiYgv+o9dd9Ar+1Ze//32GLc4AAsbqn7gliNx06DY0g/DgkoU/mYS8982gvRybFQXn1yVo1yhIMoeI4EiM1aV1Cx3KwnrKXIQR2U9/1CWhhth89gOQJusBpv0DDA==
2020-06-23 16:41:59,178 DEBUG https://wapt.domain.public:443 "POST /add_host_kerberos HTTP/1.1" 403 169
2020-06-23 16:41:59,183 DEBUG authenticate_user(): returning <Response [403]>
2020-06-23 16:41:59,183 DEBUG handle_401(): returning <Response [403]>
2020-06-23 16:41:59,183 DEBUG handle_response(): returning <Response [403]>
2020-06-23 16:41:59,183 DEBUG handle_response() has seen 0 401 responses
2020-06-23 16:41:59,184 DEBUG handle_other(): Handling: 403
2020-06-23 16:41:59,184 DEBUG handle_other(): returning <Response [403]>
2020-06-23 16:41:59,184 DEBUG handle_response(): returning <Response [403]>
FATAL ERROR : HTTPError: 403 Client Error: Forbidden for url: https://wapt.domain.public/add_host_kerberos
  File "<string>", line 1462, in <module>
  File "<string>", line 1241, in main
  File "C:\Program Files (x86)\wapt\common.py", line 5641, in register_computer
    signer = self.get_host_certificate().cn
  File "C:\Program Files (x86)\wapt\common.py", line 1969, in post
    req.raise_for_status()
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\models.py", line 940, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: https://wapt.domain.public/add_host_kerberos
Exception at 0044233C: EPyIOError:
HTTPError: 403 Client Error: Forbidden for url: https://wapt.domain.public/add_host_kerberos.
Notez qu'avant le register, j'ai fait un klist purge. Voici le résultat du klist après le register
