Ci-dessous le résultat de la commande en question.
Microsoft Windows [version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Tous droits réservés.
C:\Windows\system32>wapt-get install -l debug stjo-flashplayer
Current loglevel : DEBUG
2018-10-03 11:37:56,421 DEBUG Default encoding : ascii
2018-10-03 11:37:56,421 DEBUG Setting encoding for stdout and stderr to cp850
2018-10-03 11:37:56,421 DEBUG Python path ['C:\\Program Files\\wapt', 'C:\\Progr
am Files\\wapt\\python27.zip', 'C:\\Program Files\\wapt\\DLLs', 'C:\\Program Fil
es\\wapt\\lib', 'C:\\Program Files\\wapt\\lib\\plat-win', 'C:\\Program Files\\wa
pt\\lib\\lib-tk', 'C:\\Program Files\\wapt', 'C:\\Program Files\\wapt\\lib\\site
-packages', 'C:\\Program Files\\wapt\\lib\\site-packages\\pywin32-221-py2.7-win3
2.egg']
2018-10-03 11:37:56,421 INFO Using local waptservice configuration C:\Program Fi
les\wapt\wapt-get.ini
2018-10-03 11:37:56,421 DEBUG Config file: C:\Program Files\wapt\wapt-get.ini
2018-10-03 11:37:56,431 DEBUG Thread 10116 is connecting to wapt db
2018-10-03 11:37:56,441 INFO User Groups:[]
2018-10-03 11:37:56,441 DEBUG WAPT base directory : C:\Program Files\wapt
2018-10-03 11:37:56,441 DEBUG Package cache dir : C:\Program Files\wapt\cache
2018-10-03 11:37:56,441 DEBUG WAPT DB Structure version;: 20180303
2018-10-03 11:37:56,441 DEBUG Checking if old install in progress
2018-10-03 11:37:56,451 DEBUG Thread 10116 is connecting to wapt db
2018-10-03 11:37:56,451 DEBUG DB Start transaction
2018-10-03 11:37:56,451 DEBUG reset stalled install_status in database
2018-10-03 11:37:56,461 INFO Status :
2018-10-03 11:37:56,461 DEBUG DB commit
installing WAPT packages stjo-flashplayer
2018-10-03 11:37:56,572 INFO   Use cached package file from C:\Program Files\wap
t\cache\stjo-flashplayer_31.0.0.108-2_all_all.wapt
2018-10-03 11:37:56,681 DEBUG Stores cert chain check in cache
2018-10-03 11:37:56,681 DEBUG Downloaded : {'downloaded': [], 'skipped': [u'C:\\
Program Files\\wapt\\cache\\stjo-flashplayer_31.0.0.108-2_all_all.wapt'], 'error
s': [], 'packages': [PackageEntry('stjo-flashplayer','31.0.0.108-2') ]}
Installing stjo-flashplayer
2018-10-03 11:37:56,691 INFO Register start of install C:\Program Files\wapt\cac
he\stjo-flashplayer_31.0.0.108-2_all_all.wapt as user admin1 to local DB with pa
rams {}
2018-10-03 11:37:56,691 INFO Interactive user:admin1, usergroups []
2018-10-03 11:37:56,792 INFO Status : Installing package stjo-flashplayer versio
n 31.0.0.108-2 ...
2018-10-03 11:37:56,792 DEBUG DB Start transaction
2018-10-03 11:37:56,792 DEBUG DB commit
2018-10-03 11:37:56,802 DEBUG DB commit
2018-10-03 11:37:56,812 INFO Control data for package C:\Program Files\wapt\cach
e\stjo-flashplayer_31.0.0.108-2_all_all.wapt verified by certificate SSLCertific
ate cn=stjo-private
2018-10-03 11:37:56,812 INFO Installing package C:\Program Files\wapt\cache\stjo
2018-10-03 11:37:56,822 INFO Unzipping package C:\Program Files\wapt\cache\stjo-
flashplayer_31.0.0.108-2_all_all.wapt to directory c:\users\admin1\appdata\local
\temp\waptgjmdej
2018-10-03 11:37:57,542 INFO Package has a setup.py, code signing certificate is
 required.
2018-10-03 11:37:57,552 DEBUG Certificate {'countryName': u'FR', 'commonName': u
'stjo-private', 'emailAddress': u'administratif@saintjoseph-machecoul.fr', 'orga
nizationName': u'Lyc\xe9e Saint Joseph', 'localityName': u'MACHECOUL'} is truste
d by root CA stjo-private
2018-10-03 11:37:57,552 DEBUG Checking signature with SSLCertificate cn=stjo-pri
vate
2018-10-03 11:37:57,552 DEBUG OK with SSLCertificate cn=stjo-private
2018-10-03 11:37:57,552 INFO Package issued by {'countryName': u'FR', 'commonNam
e': u'stjo-private', 'emailAddress': u'administratif@saintjoseph-machecoul.fr',
'organizationName': u'Lyc\xe9e Saint Joseph', 'localityName': u'MACHECOUL'}
2018-10-03 11:37:57,752 INFO Unzipped files verified by certificate SSLCertifica
te cn=stjo-private
2018-10-03 11:37:57,752 INFO   sourcing install file c:\users\admin1\appdata\loc
al\temp\waptgjmdej\setup.py
2018-10-03 11:37:57,752 DEBUG Import source c:\users\admin1\appdata\local\temp\w
aptgjmdej\setup.py as __waptsetup_v4t01k8viw__
2018-10-03 11:37:57,762 INFO Install parameters : {}
2018-10-03 11:37:57,762 DEBUG DB Start transaction
2018-10-03 11:37:57,762 DEBUG DB commit
2018-10-03 11:37:57,772 INFO   executing install script
Installing flash for firefox2018-10-03 11:37:57,792 DEBUG DB Start transaction
2018-10-03 11:37:57,792 DEBUG DB commit
MSI install_flash_player_31_plugin.msi already installed. Skipping msiexec2018-1
0-03 11:37:57,822 DEBUG DB Start transaction
2018-10-03 11:37:57,822 DEBUG DB commit
Installing flash for internet explorer if < win102018-10-03 11:37:57,832 DEBUG D
B Start transaction
2018-10-03 11:37:57,832 DEBUG DB commit
MSI install_flash_player_31_active_x.msi already installed. Skipping msiexec2018
-10-03 11:37:57,861 DEBUG DB Start transaction
2018-10-03 11:37:57,861 DEBUG DB commit
Disable autoupdate2018-10-03 11:37:57,871 DEBUG DB Start transaction
2018-10-03 11:37:57,871 DEBUG DB commit
2018-10-03 11:37:57,871 INFO Replacing C:\Windows\System32\Macromed\Flash\mms.cf
g
2018-10-03 11:37:57,881 INFO Run "sc delete AdobeFlashPlayerUpdateSvc"
2018-10-03 11:37:57,911 CRITICAL Fatal error in install script: CalledProcessErr
orOutput: Command 'sc delete AdobeFlashPlayerUpdateSvc' returned non-zero exit s
tatus 1.
Output:Accès refusé.
  File "C:\Program Files\wapt\common.py", line 3328, in install_wapt
  File "c:\users\admin1\appdata\local\temp\waptgjmdej\setup.py", line 40, in ins
tall
    run('sc delete AdobeFlashPlayerUpdateSvc')
  File "C:\Program Files\wapt\common.py", line 3119, in run
    return ensure_unicode(setuphelpers.run(*arg,pidlist=self.pidlist,**args))
  File "C:\Program Files\wapt\setuphelpers.py", line 983, in run
CalledProcessErrorOutput: Command 'sc delete AdobeFlashPlayerUpdateSvc' returned
 non-zero exit status 1.
2018-10-03 11:37:57,911 DEBUG Cleaning package tmp dir
2018-10-03 11:37:57,931 DEBUG DB Start transaction
2018-10-03 11:37:57,941 DEBUG DB commit
2018-10-03 11:37:57,951 DEBUG Removing module: __waptsetup_v4t01k8viw__, refcnt:
 4
2018-10-03 11:37:57,971 DEBUG Check if host package "912BC1D2-A878-E211-8BEE-505
054503030" is available
2018-10-03 11:37:57,982 DEBUG Checking if 912BC1D2-A878-E211-8BEE-505054503030 (
=3) is installed/outdated
2018-10-03 11:37:58,002 DEBUG store status in DB
2018-10-03 11:37:58,002 DEBUG DB Start transaction
2018-10-03 11:37:58,002 DEBUG DB commit
2018-10-03 11:37:58,002 INFO Status :
2018-10-03 11:37:58,012 DEBUG DB commit
2018-10-03 11:37:58,012 CRITICAL Package stjo-flashplayer not installed due to e
rrors : CalledProcessErrorOutput: Command 'sc delete AdobeFlashPlayerUpdateSvc'
returned non-zero exit status 1.
FATAL ERROR : CalledProcessErrorOutput: Command 'sc delete AdobeFlashPlayerUpdat
eSvc' returned non-zero exit status 1.
  File "<string>", line 1215, in <module>
  File "<string>", line 432, in main
  File "C:\Program Files\wapt\common.py", line 4185, in install
    explicit_by=(installed_by or self.user) if request in apackages else None
  File "C:\Program Files\wapt\common.py", line 3405, in install_wapt
    raise e
setuphelpers.CalledProcessErrorOutput:
Exception at 0043EC7F: EPyException:
Output:Acc├¿s refus├®.
