[SOLVED] Programs Menu Shortcut: Create Folder?
jnicol
09 mars 2018 - 15:31
Hi,
I have been using
create_programs_menu_shortcut
to make shortcuts in the Programs Menu under Windows 10.
I would like to create a folder in the Programs Menu with my shortcuts arranged inside the folder. Can this be done? Is there a function that will do this?
Here is an example:
FOLDER1
- Shortcut1
- Shortcut2
FOLDER2
- Shortcut 3
- Shortcut 4
Thanks in advance.
John
09 mars 2018 - 16:24
there are 2 issues in the create_programs_menu_shortcut function:
  • it does not create subfolders of start programs menu prior to create the shortcut.
    it creates the shortcuts in \startup and not in \startup\Programs
I have pushed a fix which will be included in final 1.5.1.
https://github.com/tranquilit/WAPT/comm ... f5c613da0c
meanwhile, you can workaround by using
winshell.programs
function which returns the StartPrograms path and add your subfolder
import winshell
sc_path = makepath(winshell.programs(1),'FOLDER1','Shortcut1')
ensure_dir(sc_path)
create_shortcut(sc_path,makepath(programfiles32,'myapp','toto.exe'))
jnicol
13 mars 2018 - 09:16
Thank you very much! I will give this a shot.
Regards
John
htouvet a écrit : ↑09 mars 2018 - 16:24 there are 2 issues in the create_programs_menu_shortcut function:
winshell.programs
import winshell
ensure_dir(sc_path)
