Suite à la diffusion concernant la faille et l'upgrade à la version 2.0.0.9450, je rencontre un message d'erreur lorsque je lance l'upgrade :
The following packages will be upgraded:
  aspell krb5-locales krb5-user libaspell15 libgssapi-krb5-2 libgssrpc4 libk5crypto3 libkadm5clnt-mit11 libkadm5srv-mit11 libkdb5-9 libkrb5-3 libkrb5support0
  libnss-systemd libpam-systemd libsystemd0 libudev1 linux-image-4.19.0-17-amd64 systemd systemd-sysv tis-waptserver tis-waptsetup udev
22 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/131 MB of archives.
After this operation, 4,096 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Fatal Python error: initfsencoding: Unable to get the locale encoding
ModuleNotFoundError: No module named 'encodings'
Current thread 0x00007f22ac063740 (most recent call first):
Aborted
E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 returned an error code (1)
E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
Dois-je "désinstaller" python 2.7 ?
Auriez-vous une piste pour régler ce message d'erreur ?
En vous remerciant par avance.
