j'utilise wapt sur un serveur Debian.
Version WAPT Server : 1.8.2
Version WAPT Agent : 1.8.0.6641
version WAPT Setup : 1.8.2.7267
Version WAPT Deploy : 1.8.2.7267
Statut de la base : OK (1.8.2.0)
Cette installation a toujours fonctionné mais depuis un moment (j'ignore exactement depuis quand), il m'est impossible d'enregistrer de nouvelles machines, celle-ci n'apparaissent pas dans la console et j'ai ce genre de message dans les logs :
Sep 25 08:20:49 wapt waptserver[16335]: 2020-09-25 08:20:49,258 [waptws ] WARNING Application rejected connection
Sep 25 08:21:03 wapt waptserver[16335]: 2020-09-25 08:21:03,125 [waptserver ] CRITICAL Get_websocket_auth_token failed EWaptAuthenticationFailure(u'Unknown host UUID 4C4C4544-0033-3110-8036-C2C04F335A32. Please register first.',)
Sep 25 08:21:03 wapt waptserver[16335]: 2020-09-25 08:21:03,185 [waptws ] WARNING SocketIO connection refused for uuid 4C4C4544-0033-3110-8036-C2C04F335A32, sid 379abcf3e67946b294732b48f4cd9467: SocketIO connection not authorized, invalid token: 400 Bad Request: The browser (or proxy) sent a request that this server could not understand., instance
Sep 25 08:21:03 wapt waptserver[16335]: 2020-09-25 08:21:03,192 [waptws ] WARNING Application rejected connection
Sep 25 08:21:17 wapt waptserver[16335]: 2020-09-25 08:21:17,002 [waptserver ] CRITICAL update_host failed EWaptMissingCertificate(u'You try to update status of an unknown host 4C4C4544-0033-3110-8036-C2C04F335A32 (gim-cm-129-01.iut-chartres.lan). Please register first.',)
Sep 25 08:21:23 wapt waptserver[16335]: 2020-09-25 08:21:23,991 [waptserver ] WARNING Unauthenticated registration for gim-cm-129-01.iut-chartres.lan
Sep 25 08:21:24 wapt waptserver[16335]: 2020-09-25 08:21:24,517 [waptdb ] CRITICAL Error updating data for 4C4C4544-0033-3110-8036-C2C04F335A32 : OSError: [Errno 13] Permission denied: '/var/www/ssl'
Sep 25 08:21:24 wapt waptserver[16335]: 2020-09-25 08:21:24,519 [waptserver ] CRITICAL add_host failed OSError(13, 'Permission denied')
Sep 25 08:22:03 wapt waptserver[16335]: 2020-09-25 08:22:03,279 [waptserver ] CRITICAL Get_websocket_auth_token failed EWaptAuthenticationFailure(u'Unknown host UUID 4C4C4544-0033-3110-8036-C2C04F335A32. Please register first.',)
Sep 25 08:22:03 wapt waptserver[16335]: 2020-09-25 08:22:03,334 [waptws ] WARNING SocketIO connection refused for uuid 4C4C4544-0033-3110-8036-C2C04F335A32, sid f27011798b2541f9b0fb6dc44872fa5d: SocketIO connection not authorized, invalid token: 400 Bad Request: The browser (or proxy) sent a request that this server could not understand., instance
Sep 25 08:22:03 wapt waptserver[16335]: 2020-09-25 08:22:03,336 [waptws ] WARNING Application rejected connection
Sep 25 08:22:32 wapt waptserver[16335]: 2020-09-25 08:22:32,946 [waptws ] WARNING Invalid session None
Sep 25 08:22:43 wapt waptserver[16335]: 2020-09-25 08:22:42,999 [waptws ] WARNING Invalid session None
Sep 25 08:23:03 wapt waptserver[16335]: 2020-09-25 08:23:03,434 [waptserver ] CRITICAL Get_websocket_auth_token failed EWaptAuthenticationFailure(u'Unknown host UUID 4C4C4544-0033-3110-8036-C2C04F335A32. Please register first.',)
Sep 25 08:23:03 wapt waptserver[16335]: 2020-09-25 08:23:03,487 [waptws ] WARNING SocketIO connection refused for uuid 4C4C4544-0033-3110-8036-C2C04F335A32, sid 17bab681c3c244e890177a04a38877df: SocketIO connection not authorized, invalid token: 400 Bad Request: The browser (or proxy) sent a request that this server could not understand., instance
Sep 25 08:23:03 wapt waptserver[16335]: 2020-09-25 08:23:03,488 [waptws ] WARNING Application rejected connection
Sep 25 08:24:03 wapt waptserver[16335]: 2020-09-25 08:24:03,570 [waptserver ] CRITICAL Get_websocket_auth_token failed EWaptAuthenticationFailure(u'Unknown host UUID 4C4C4544-0033-3110-8036-C2C04F335A32. Please register first.',)
Sep 25 08:24:03 wapt waptserver[16335]: 2020-09-25 08:24:03,629 [waptws ] WARNING SocketIO connection refused for uuid 4C4C4544-0033-3110-8036-C2C04F335A32, sid f808cb633f794c96ba85bdad7353224e: SocketIO connection not authorized, invalid token: 400 Bad Request: The browser (or proxy) sent a request that this server could not understand., instance
Sep 25 08:24:03 wapt waptserver[16335]: 2020-09-25 08:24:03,630 [waptws ] WARNING Application rejected connection
Sep 25 08:25:03 wapt waptserver[16335]: 2020-09-25 08:25:03,725 [waptserver ] CRITICAL Get_websocket_auth_token failed EWaptAuthenticationFailure(u'Unknown host UUID 4C4C4544-0033-3110-8036-C2C04F335A32. Please register first.',)
Sep 25 08:25:03 wapt waptserver[16335]: 2020-09-25 08:25:03,777 [waptws ] WARNING SocketIO connection refused for uuid 4C4C4544-0033-3110-8036-C2C04F335A32, sid cbb4ec75deae44c9bd42147db89bc621: SocketIO connection not authorized, invalid token: 400 Bad Request: The browser (or proxy) sent a request that this server could not understand., instance
Sep 25 08:25:03 wapt waptserver[16335]: 2020-09-25 08:25:03,778 [waptws ] WARNING Application rejected connectionMerci pour votre aide.
