Hi,
Is it a way to change many packet to restricted instead of base without recreating it nor changing version ?
I've checked in the postgresql database, but not found.
Regards
[RESOLU] bulk change packet section to restricted
Hi Nliaudat,
then modifying the control file and doing a
by default the build-upload command does not increment version number (you need to add a -i flag to increment)
Cheers,
On a management computer with the private key configured, you can script something that do a
wapt-get edit tis-mypackageCode : Tout sélectionner
wapt-get build-upload c:\waptdev\tis-mypackageCheers,
