[RESOLU] Package remove metro apps
Avatar du membre
Mathieu
14 juil. 2019 - 10:18
depuis peux j'ai un soucis avec un paquet Remove Metro apps, celui-ci fonctionnait parfaitement mais depuis quelques installation le paquet ce retrouve en erreur, alors que je n'ai pas touché au script depuis la mise en PROD du paquet
voici le message :
Starting the debloating process...Trying to remove Microsoft.BingFinance
NoneTrying to remove Microsoft.BingNews
NoneTrying to remove Microsoft.BingSports
NoneTrying to remove Microsoft.BingWeather
NoneTrying to remove Microsoft.Getstarted
NoneTrying to remove Microsoft.XboxApp
NoneTrying to remove Microsoft.ZuneMusic
NoneTrying to remove Microsoft.ZuneVideo
NoneTrying to remove Microsoft.MinecraftUWP
NoneTrying to remove Microsoft.BingFoodAndDrink
NoneTrying to remove Microsoft.BingTravel
NoneTrying to remove Microsoft.BingHealthAndFitness
NoneTrying to remove Microsoft.WindowsReadingList
NoneTrying to remove Flipboard.Flipboard
NoneTrying to remove ShazamEntertainmentLtd.Shazam
NoneTrying to remove king.com.CandyCrushSaga
NoneTrying to remove king.com.CandyCrushSodaSaga
NoneTrying to remove king.com.*
NoneTrying to remove ClearChannelRadioDigital.iHeartRadio
NoneTrying to remove 4DF9E0F8.Netflix
NoneTrying to remove 6Wunderkinder.Wunderlist
NoneTrying to remove Drawboard.DrawboardPDF
NoneTrying to remove 2FE3CB00.PicsArt-PhotoStudio
NoneTrying to remove D52A8D61.FarmVille2CountryEscape
NoneTrying to remove TuneIn.TuneInRadio
NoneTrying to remove TheNewYorkTimes.NYTCrossword
NoneTrying to remove 828B5831.HiddenCityMysteryofShadow
NoneTrying to remove Microsoft.Advertising.Xaml
NonePreviously removed by wapt :
Remaining metro apps ;) : Traceback (most recent call last):
  File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt
  File "c:\windows\temp\waptxq1txp\setup.py", line 102, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4399, in run_powershell
    raise ValueError(u'%s returned non json data:\n%s' % (cmd,result))
UnicodeDecodeError: 'ascii' codec can't decode byte 0x8a in position 47313: ordinal not in range(128)
'ascii' codec can't decode byte 0x8a in position 47313: ordinal not in range(128) : faulty string is ''[\r\n    {\r\n        "Name":  "1527c705-839a-4832-9118-54d4Bd6a0c89",\r\n        "Publisher":  "CN=Microsoft Windows, O=Microsoft Corporation, L=Redmond, S=Washington, C=US",\r\n        "PublisherId":  "cw5n1h2txyewy",\r\n        "Architecture":  11,\r\n        "ResourceId":  "neutral",\r\n        "Version":  "10.0.16299.15",\r\n        "PackageFamilyName":  "1527c705-839a-4832-9118-54d4Bd6a0c89_cw5n1h2txyewy",\r\n        "PackageFullName":  "1527c705-839a-4832-9118-54d4Bd6a0c89_10.0.16299.15_neutral_neutral_cw5n1h2txyewy",\r\n        "InstallLocation":  "C:\\\\Windows\\\\SystemApps\\\\Microsoft.Windows.FilePicker_cw5n1h2txyewy",\r\n        "IsFramework":  false,\r\n        "PackageUserInformation":  [\r\n                                       "S-1-5-21-485133025-386941804-4221807023-500 [Administrateur]: Installed",\r\n
j'ai du couper mais ça continue avec toutes les apps qui sont dans le script.
je comprend pas pourquoi du jour au lendemain le script ce met en erreur.
merci de votre aide
Modifié en dernier par Mathieu le 02 oct. 2019 - 17:45, modifié 1 fois.
- WAPT 2.2.3.12463 Entreprise
- Debian 9.9
- Windows 10 21H2 & Windows 11 22h2
Avatar du membre
19 juil. 2019 - 19:08
Bonjour Mathieu,
Mathieu a écrit : 14 juil. 2019 - 10:18 depuis peux j'ai un soucis avec un paquet Remove Metro apps, celui-ci fonctionnait parfaitement mais depuis quelques installation le paquet ce retrouve en erreur, alors que je n'ai pas touché au script depuis la mise en PROD du paquet
Quelle version de WAPT, quel version OS?
Mathieu a écrit : 14 juil. 2019 - 10:18 voici le message :
Les machines ont aussi leurs sautes d'humeur, leur petits caprices, etc. Chaque mise à jour Windows peut être l'occasion de découvrir de nouveaux comportements et de nouvelles aberrations :-) .
Dans le cas présent, le script Powershell renvoie un json avec encoding qui n'était pas attendu. Il semble que le blob json a du être coupé, non?
Denis Cardon
Avatar du membre
Mathieu
22 juil. 2019 - 14:10
Pardon j'ai oublié de le préciser
- WAPT 1.7.4.6143 Entreprise
- Debian 9.9
Toutes nos machines on la même version de Win 10 1709.
les mises à jour sont déployé via WSUS donc pour ce qui est de l'OS les machines sont identique.
Pour le "Blob json" je connait pas je n'ai rien touché
- Debian 9.9
Avatar du membre
25 juil. 2019 - 11:12
ça serait intéressant de voir ce qui cloche dans la sortie du powershell...
dans le paquet à la fin de la procédure install()
remplacer
    print(u'Remaining metro apps ;) : ')
    print(u'\n'.join(sorted(u'"%(Name)s", # (%(Version)s)",' % app for app in run_powershell('Get-AppxPackage -AllUsers'))))
par
    print(repr(run_powershell('Get-AppxPackage -AllUsers',output_format='txt')))
et pouvez-vous poster le résultat d'une installation sur une machine ùu ça pose problème?
Avatar du membre
Mathieu
30 juil. 2019 - 17:46
Je pense qu'il y a eu un soucis j'ai bien remplacer les lignes
  File "c:\waptdev\futur-OptionW10_remove_metroapps_PROD-wapt\setup.py", line 104, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4384, in run_powershell
    raise CalledProcessErrorOutput(e.returncode,cmd,e.output)
CalledProcessErrorOutput: Command u'Get-AppxPackage -AllUsers' returned non-zero exit status -196608.
Output:?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
FATAL ERROR : CalledProcessErrorOutput: Command u'Get-AppxPackage -AllUsers' returned non-zero exit status -196608.
Output:…ù?‘«?‘?ú†?ý‘?ù‘ñªƒû?‡­¾†æ¾†ªÿ†?ð„??‘ûî‘«ü‘?ª‘¾?‘?ªÆøÿ‘¾Ý‘­œ‘?¸Æûý‡øÿƒïÿ‘??‡?ý‘«¸ƒ?©‡?¬‡?¾‘¾ü‘ûî†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘«?‘«?‘«õƒ??ƒæ?‘«?‡­?‡?¸ƒ??ƒæ?‡??†æ­ƒæ?‡??†æ­†ªÿ„÷ð†?î‘«ý‘¾Ý‘?ªƒ??ƒæ?‘«?„¾©‡?©‡?¾‘?­‘¾ï‘?ô…æ?ƒ??ƒ?ÿ†ªÿ„Ïð‡?©‡?æ‘«?‘æý‡?­‡ªÿ‘??‡?÷‡øÿ†ÿÿ„ñ?†æ«†ªÿ„¬ð‡?æ‡?ø„?ï‡?î‘?ðƒ?ï†?¯‡­¾ƒ?ïƒ?¬„æ?‡æ?…æ?ƒ??ƒ?ÿ†ªÿ†?ð‘û¸‘«Ï†?ú‡¾ï‘?ªÆøÿ‡?ü‘ñûÆû¾ƒ??ƒæ?‘û?‘«œ‘?Ï„?Ï‘æî‘?ð‘?©Æøÿ‘«Ÿ‘æð‘û­‘?Ï‘?ÿ‘?î‘??‘?ÿƒ?©‘?½‘?üÆ?ÿÆ÷ï…æ?ƒ??ƒ?ÿ†ªÿ„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ðÆøÿ‘­œŠñ­‘?©†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘¾?‘?ªÆøÿ‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ÆûýÆøÿ‡?­‡?õ‘?ð‡?©Æûüƒ??ƒæ?‡­?‘?¾‡?æ‘«¸†?©‘ñî‘?¸ƒ?û†?¬‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘«Ÿ‘æð‘û­ƒ?σ?¯ƒ?ðƒ?¬‘?¬‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸Æûÿ‘?ð‘?ýƒ?ü‡?¬‘?­‘?ª‡?­‘?ÿ‘?õ‘?ý‘ææ‘û¾‡?ï†ïó…ù?ƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?¬‘?¬‘?ù‘§?Æû¾†ªÿ†?¬‡?­‘æ­‡??‘?ýƒ?ü‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?φïó‡ïÿ†ïÿ…ù?…ù?‘«?‘?ú†?ý‘?ù‘ñªƒû?‡­¾†æ¾ƒïÿ‘??‡?ª‡øÿƒïÿƒ?¨ƒ?¬Æ¬î…ù?…ù?†?ð„??‘ûî‘«ü‘?ª‘¾?‘?ª…ù?ƒ?ÿƒ?ÿ‘­Ÿ‡?­‘?õ‘øÿƒ?¾‘¾Ý‘­œ‘?¸ƒ?ý‘?Ï‘?ÿ‘ûî‘«ü‘?ª†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª‡?ü‘??‘?¸Š?¸ƒ?©‘«?‡?æ‘?ÿŠ?ý‡?¾‡?ÿ…橃??ƒ?ÿ‘?ÿ‘?¸‘¾ù‡?¾‘?ÿƒ?¾‘«œ‡?©‘ñîƒñ¾‡?ÿ‘¾ï‘¾ª‘?üƒ?§‡­?‘«ø‡?ý„?ð‘ûî‘«ü‘?ª‘?ÿ‘û­ƒ?ü‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…ï©…ï?ƒï?‘??‡?ý‘«¸…橃??ƒ?ÿ„?ÿ‘ô?‡?­‘?ý‘øÿƒ?­‘?ô‡?ý‘«¸ƒ?©‡?ü‘??‘?¸Š?¸ƒ?¾‘?φ?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª…ïÿƒ??ƒ?ÿ„?ÿ‡?©‘?ýƒ?§‘ûæ‘÷ÿ‘ææ‡??ƒ?î‘?χ?ÿ‡?¾‘¾ü‘ûî‘?ÿ‘?ôƒ?œ‘?ª‡?ÿ‡?­‘æ­‡??‘?ýƒ?ª‘?ïƒ?ª‡?ñƒ?¾ƒ?©‡?ð‡?¾‘¾ü‘ûîÆ?ÿÆ?©ˆ¬ÿ…ï©…ï?ƒï?‘«?‘«?‘«õ…ù?ƒ?ÿƒ?ÿ‘??‡?ü‘?æ‘øÿƒ?­‘?½‘û©Š¸¸‘?ý‘?ÿƒ?¾‘«œ‡¾ø‘¾ý‘­õƒ?ï‡?­‘?ÿ‘ô?‡?­‘?ý‘?õ…ï©…ï?ƒï?‘«?‡­?‡?¸…ù?ƒ?ÿƒ?ÿ‘??‡?ÿƒ?¾‘?Ý‘æýƒ?¾‘?øƒ?ü‡?­Š¸ýƒ?üƒ?ª‡­¾‘??‡?æ‘«¸ƒ?©‘?σ?ü‘«œ‘æð‘û­‘?σ?ü‘?Ï‘?ÿ‘ô?‡?­‘?ý‘?õ…ï©…ï?ƒï?‡??…æ­ƒ??ƒ?ÿ„?ÿ‘ô?‡?­‘?ý‘øÿ‘Ïõ‡?©‡?¾‡?ø‡??‡?¾ƒ?ý‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾Š?ÿ‘øÿ‘?õ‘?¸ƒ?¾ƒ?Ï‘ûæ‘?ÿ‘«ª‡?¸‘ûî‘?©‘?ð‡?©‘ïÿ‘ûî‡?î‡?ù‘?¾ƒûÏ…ù?ƒ?ÿƒ?ÿ‘??‘?ÿ‘«ª‡?¸‘ûî‘?©‘?ð‡?©‘ïÿ‘ûî‡?î‡?ù‘?¾ƒ?φ?ù„??ƒ?¸‡?¾ƒ?ï‡?æ‘ñ¸‡?¸ƒ??‘?øƒ?ýŠ?Ï‘?݇?æ…ï©…ï?ƒï?‡??…æ­ƒ??ƒ?ÿ„?ÿ‘ô?‡?­‘?ýƒ?ýƒ?ª‘û¸‘?ï‡?ýŠ?ý‘?ï‡?æ‘?ÿƒ?¾‘«œ‘æð‘û­‘?σ?üƒ??ƒ?ª‘¾­‘?Ï‘?ÿ‡?õƒ?©‘ñœ‘¾î‘«ü‘û©‘澑û¾ƒ?ï‡?ð‡?ª‡?¸‡?ù‘?¾ƒûÏ…ù?…ù?„÷ð†?î‘«ý‘¾Ý‘?ª…ù?ƒ?ÿƒ?ÿ‘??‘?ÿ‘?ù‘?ýƒ?¾‘?øƒ?ü‘?ª‡?ÿ‘«ý‘¾Ýƒ?ª‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…ï©…ï?ƒï?‘«?„¾©‡?©‡?¾‘?­‘¾ï‘?ô…ù?ƒ?ÿƒ?ÿƒ??‘?­‘¾Ý‘­œƒ?¾‘?øƒ?üƒ?Ï‘û¸‘¾ô‘?ï‘Ïÿ‡?©‡?¾‘?­‘¾ï‘?ô‡?ÿ‡?îƒ?ýƒ?ª‡?æ‘ñ¸‡?¸‡?­‡?¾ƒûý…ù?…ù?„Ïð‡?©‡?æ‘«?‘æý‡?­…ù?ƒ?ÿƒ?ÿŠ??‡?œ‡?¸‘øÿƒ?¾‘«Ý‘æý‡?­‘?ÿ‡?¾‘?ÿ‘ûîŠ?©‡?¾‘?ÿ‡?©‡¾î‘??ƒ?üƒ??‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñªƒ?©‘??ƒ?ü‘?ô‘?ª‡?æ…æüƒ??ƒ?ÿ‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûîƒ?ïƒ?©‘??‡?÷ˆ¬ÿƒÿÿ‘­œŠñ­‘?©ƒ?ü‘?χ?ÿ‡­¾‘?ïƒ?¸‡?îˆ÷ÿ†ÿÿ„ñ?ˆ¬ÿƒÿÿ‘«Ý‘æý‡?­„?ÿ„¾?„æ?ƒ??Š?ü‘¾ý‘ñ­‡?¸ƒÝ?…ï©…ï?ƒï?‡??‡?ï‡?æ‘«?‘æý‡?­…ù?ƒ?ÿƒ?ÿŠ??‘?ï‘æý‘û¸ƒ?¾‘?ª‘ïÿ‡??‘«ù‘?Ï‘?ÿƒ?¾‘¾ð‘?ü‘?ÿƒ?©‘«Ý‘æýƒ?¾‘?Ï‘øÿƒ?­‘«ü‡?ý‘?¸‘?ÿƒ?¾‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…暑??ƒ?ÿ„øÿ‡?¾‡?ÿ‘ñ­‡?¾‡?ý‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûîƒ?ïƒ?©‘??‡?÷ˆ¬ÿƒÿÿ‘­œŠñ­‘?©ƒ?ü‘?χ?ÿ‡­¾‘?ïƒ?¸‡?îˆ÷ÿ†ÿÿ„ñ?ˆ¬ÿƒÿÿ‘«Ý‘æý‡?­„?ÿ„¾?„æ?ƒ??Š?ü‘¾ý‘ñ­‡?¸ƒÝ?…ï©…ï?ƒï?‘¾?‘?©‡?î‡??‘ñû…澃??ƒ?ÿ„?ÿ‘??‘û¸‡?¸‘øÿƒ?¾‡?ü‘ñûƒ?¾‘?Ï‘?ÿ‘û¾‡??‘?ý‡?ÿ‡?æ„÷ÿ‡?î‘?ðƒñª„ïÿ‘û¸‘渇¸¸‘?¾ƒ?ª‘??‘¾÷‘¾ð‘?§ƒ?χ?î„ÿÿ‘?¸‘?σû©…ù?…ù?„?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­…æÏƒ??ƒ?ÿ„?ÿ‘?œ‡?¾‘?ï‡?ÿ‘?©‡?ÿ‡?¾‘¾ü‘ûî‘?ÿƒ?¾‘­œŠñ­‘?©‘?ÿ‘?î‘??‘?ÿƒ?©‘?½‘?üÆ?ÿƒ?ïƒ?Ï‘ûæƒ?¾‘«œ‘æð‘û­‘?σ?©‡??‘ñ¸‡?¸‡¸¾…ù?ƒ?ÿƒ?ÿ‘?œ‡?ÿ‡?­‘æ­‡??‘?ý‡?ÿ‡?îƒ?ý‘û¾‘«ô‘?ûƒ?ý‘?σ?ü‘«œ‘æð‘û­‘?σ?üƒ??‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª‘÷ÿ‘??‡?¾‘¾ü‘?ï‡?©…ù?ƒ?ÿƒ?ÿ‘?σ?ü‡?õ‘ñ¸‘?ª‘?ð‡?ï‘?ÿ‘æî‘ñø‡­¾‡?¾‘¬ÿƒ?æ‘?σ?ü‘?­‘«œ‘?ª‘?σûü…ù?…ù?„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ð…ù?ƒ?ÿƒ?ÿ‡??‘??‘?¸‘?¸‡?ÿƒ?©‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‘?ÿƒ?¾‘«œ‘?©‘?¸‡?æ‡?­‘«¸ƒ?©‘?χ?©‘øÿ‡?¾‘?æƒ?ª‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª‘?ÿ‡?ü‘?ÿŠ?÷‡?œŠ?ï…暑??ƒ?ÿ„Ïÿƒ?ª‘?ø‡?æ‡?ÿ‘?õ‘¾õƒ?ý‘?χ?ÿ‡?îƒ?ï‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‘?ÿ‡?©‘?¾‡?¸‡?ïƒ??‡?üƒ?ý‘?ª‘ïÿ‘?­‘¾ù‘?©‘øÿ‘?î‘ñ­ƒñ¾‘÷ÿ‡?î‘æ­‘?ð‡?©‘øÿ‡?¾…ù?ƒ?ÿƒ?ÿ‘«ø‘û¸‡?ï‘?ÿƒ?¾‘?ï‘æý‘û¸‘¾­‘«üƒ?©ƒ??‘¾Ï‡?ü‘û­‘?œ‡?ÿ‡?­‘?ÿ‘??‡?­ƒ??‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñªƒ?ª‡?î‡?ÿƒ?©‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‡?ÿ‡?¾‘«ü‘û©‘ñ­‡?¸…ô?ƒ??ƒ?ÿ‘?ÿ‡?îƒ??‘?Ï‘?ÿ‡?­‘?­‡?¸‡??‡?ÿŠ?ø‘¾œ‘¾Ý‡?ñ‡?¾‘?ÿƒ?æ‚?ý‘?ª‡?ÿ‘¾ï‘¾ª‘?ü‘?ï‡?æ…暑??ƒ?ÿ…ïÿƒï?‘¾?‘?ª…ù?ƒ?ÿƒ?ÿ‡­?‘??‡?æƒ?¾‘?ª‡?ÿ‡?œ‡?¸ƒ?ï‡?ü‘??‘?¸Š?¸‘?ÿ‘û­ƒ?üƒ?ª‡??‘û¾‡?σ?¾‘«ª‘?œ‘?ªƒÿÿ‡?­‘?¾ˆ÷ÿ‘?ÿ‡?î‡?ð‡?î‘?ý‘û¸ƒ?õƒÝîƒ?ª‘?χ?ÿ‡?î‘?ï‡?ÿ‘?æ‘øÿ‡?¾…ïÿƒ??ƒ?ÿ‘?ÿ‘ûî‡?œ‘«¸‡?©‘?ÿƒ?ï‘?ô‘¾ý‘?­‘?ªƒ?ü‡?œŠ??‡?¾‡?ÿ‡?­‘øÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘¾î‘û¾ƒ?χ?ü‘ûî‘?¸‘?ªƒ?ü‘?χ?©‘øÿƒ?­…ù?ƒ?ÿƒ?ÿ‘?ü‡?ü‘«¸ƒ?©‘?­‘¾ï‘?ôƒ?©‘û?‡?¾‘øÿƒ?¾‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ƒ?ý‘?χ?ÿ‡?œ‡?¸ƒ?ï‡?¾‘øÿ‡?¾‡?ÿ‡?­‘æ­‡??‘?ýƒ?ü‡??‘û¾‡?ï‘ñ¾ƒûü…ïÿƒ??ƒ?ÿ„øÿƒ?¾‘¾Ý‘­œ‘?¸ƒ?ý‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘?ª‘?ÿ‡?¾‘¾©‡?¾‡?ÿ‡?­‘æ­‡??‘?ý‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒñ¾‘?ÿ‡?­‡?ÿ‡?îƒ?ü‘?ªƒ?ü‘?œ‘?ý‡?œ‡??‡?¾…ïÿƒ??ƒ?ÿ‘?ÿ‡?©Š?ýƒ?ü‡?­Š¸ýƒ?ü‘?ª‘÷ÿ‘æî‘?ÿƒ?¾‘?ø‘?ýЏð‡?ïƒ?¾‘¾?‘?ª‡?ÿ‘ûîƒ?ï‘û¸‘?ï‡?ýŠ?ýŠ?ï…æüƒ??ƒ?ÿ‘?ÿ‘æî‘?ðŠ?ÿ‘?ï‡?©‘øÿƒ?¾‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ƒ?ý‘?χ?ÿ‡?œ‡?¸ƒñï‡?ÿ‘¾æ‘¾ô‘?ÿ‡?¾‡?ÿ‡?­‘æ­‡??‘?ýƒ?ü‡?χ?ÿ‡?œ‡?¸ƒûï…ù?…ù?„?ð‘?÷‡?œ‘¾ï‘ûî‘«?‘¾ª‡¾œ…ù?ƒ?ÿƒ?ÿŠ??‘¾Ý‘¾©ƒ?ï‘?ª‡?ÿ‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî‡?ÿ‡?­‘?ÿ‘??‡?­ƒ?ï‘?Ï‘øÿƒ?­‘?ü‡?ü‘«¸ƒ?©‘?­‘¾ï‘?ô‘?ÿƒ?ïƒ?ª‘û¾‘?ý‘¾õ‡?ü‘?ý…ïÿƒ??ƒ?ÿ‘?ÿ‘û­ƒ?ü‘?ª‡?ÿ‡?­‘?¸‘ñ½ƒ?¾ƒ?Ï‘û¾‘¾ô‘«ý‘û©‘澑û¾ƒ?ï‘?χ?©†?§„??‘?÷‡?œ‘¾ï‘ûî‘«?‘¾ª‡¾œ‡??‘?¾‡?¾‘û¾‘?œƒ?©…ù?ƒ?ÿƒ?ÿ‘?Ÿ‡?ÿ‡?­‘æ­‡??‘?ý‘÷ÿƒ?¾‘«ð‘¾Ï‘¾Ýƒ?¾‘?øƒ?ü‘?ª‡?ÿ‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª…ù?ƒ?ÿƒ?ÿŠ?Ï‘¾Ý‘¾©ƒ?¾‘?χ?©‘øÿƒ?¾‘??‘¾õ‡?ü‘?ý…ï©…ï?ƒï?‘«Ÿ‘æð‘û­…æÏƒ??ƒ?ÿ„?ÿŠ?÷‡?œ‘?ï‘øÿ‡?¾‘?ÿ‘æî‘?ð‘?©‡?¾‡?ÿŠ?ø‘¾œ‘¾Ý‘??ƒ?ü‘?ùƒ?ï‘?ªƒ?ü‘?ø‘?ýЏð‡?ï‡?¾Š?ÿ‘?ô‡?©‘?æ‡?ªƒ?¸‘«œ‘æðƒ?¾‘¾ü‘?ÿ‘ñª‡?¾Š?ÿ‘?ï‘?¸‡?©…ù?ƒ?ÿƒ?ÿ‘û¾‡?ï‘??ƒ?ü‘?χ?©‘øÿ‘Ïõ‡?©‡?¸ƒ?¾‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒñª‡?ÿ‘¾æƒ?ü‘?ü‘?ÿ‡?¾‘?ðƒ?ª‘?ü‘?æ‡?ÿƒ?¸…ù?ƒ?ÿƒ?ÿ‘«?‡­?‡?¸‘?ÿ‡?ü‡?ÿŠ?ø‘¾œ‘¾Ýƒ§?„øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘?ø‡?æŠÿÿ‡?ïƒ?¾ƒ?©ƒ?ðƒýî‡?ÿ‘?©‘?ÿ‘?ù‘§?ƒ?¾‡?î‡?ÿ…橃??ƒ?ÿ‘?ÿ‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸ƒûï…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ïƒ?©ƒ?ðƒýî‘øÿƒ?¾‘?ï‡?÷ƒ?¾‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?Ï‘?ÿ‡?ü‘øÿƒ?æ‘?χ?©…ù?ƒ?ÿƒ?ÿƒ?ª‘û¾‡?ï‘??‡?ÿ‘?ï‘?©‡?­ƒûÏ…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ï‘ûæ‘?ÿ‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸ƒñï‘?ÿ‘ñ¾‘¾æ‘?ðƒ?¸‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘ñø‘?­…ô?ƒ??ƒ?ÿ‘?ÿ‡?©‘?ý‘?ÿ‘?œ‘ñî‘?­‡?¾ƒÿÿ‡æ¯ƒ÷¸†?ÿ‡?îƒ?ü‘«ø‡?懸¾‡?ÿŠ?ø‘¾œ‘¾Ý‡?¾‡?ÿƒ?©‘ñ½‘?î‘?ÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘¾©‡?ñ‘澑û¾…æïƒ??ƒ?ÿ‘øÿ‡?î‡?ü‘?æ‡?ÿ‡?îƒ?ü‡­¾‘??‡?懸¾†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª‡­¾ƒ?¾‘?χ?©†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª„øÿ‡?¾‡?ÿ‡??‘ñæ‘?ï‡?ï‘?ÿƒ?æ‘ñ½‘?î‘?ÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘ûîƒ?ï‘?ý‡?©‡¾î‡??Š?ÿ‘øÿ‘Ïõ‡?©‡?¾‡?ø‡??‡?¾ƒ?ý‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾…ù?ƒ?ÿƒ?ÿ‘?ø‘?ý‡?©‡?ÿ‡?îƒ?ü‘«Ý‘æýƒ?¾ƒ?Ï‘?î‘?¦‡?ï†ÿÿ„ñ?‘?ÿ‡??‡??‘?¸‘¾ªŠ?üƒ?ü‡?¾‘÷ÿ‘ûî‡?ÿ‡?­‡?ÿ‡?îƒ?ü‘«Ý‘æýƒ?¾ƒ?Ï‘?î‘?¦‡?ï‘?ÿ‡?œ‘?¸ƒûü…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ï‘ûæƒ?¾‘­œŠñ­‘?©ƒ?ª‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘?ª‘?ÿ‡?¾‘¾©‡?¾…ù?ƒ?ÿƒ?ÿ‘?ø‘?ýЏð‡?ïƒ?¾‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?σ?ª‘?œƒ?ý‘?ªƒ?ü‘?œ‘?ý‡?œ‡??‡?¾‘?ÿ‡?©Š?ýƒ?ü‡?­Š¸ýƒ?ü‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«ü‡?©…ù?ƒ?ÿƒ?ÿ‘û¸‘?ï‡?ýŠ?ýŠ?ïƒ?ü‘«œ‘æðƒ?¾‡?­‡?õ‘?ð‡?©ƒ?ü‘?Ï‘?ÿ‘æî‘?ð‘?©ƒû¾…ù?…ù?ƒ?ÿƒ?ÿ‘«?‡?æŠ?ÿ‡?œ‡?¸ƒ?¾‘ûæƒ?¾‘­œŠñ­‘?©‡?ÿ‘¾æ‘?ÿŠ?÷‡?œ‘?ï‡?ÿ‘?©‘?ÿ‘æî‘?ð‘?©ƒ?¾‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…廙??ƒ?ÿ‡?ÿ‘¾ï‘¾ª‘?üƒ?§‘?ª‘?ÿ‡?î‘?ðƒ?ï…ï§…Ï?ƒ?½‡ªÿ‘?¬‘æî‘?ð‘?©Æû¾ƒ?«…ù?ƒ?ÿƒ?ÿ‚?î‘øÿ‡?¾‘?ÿ‘¾æ‘ñª‘澇?¾ƒ?ü‘û¸‘¾Ï‡?ñ‘û¾ƒ?ï‘ûæƒ?¾‘­œŠñ­‘?©‘?ÿƒ?ïƒ?ª‡?î‡??‡?­‡?¾ƒ?ýƒ?χ?­‘?øƒ?ªƒ?ù…︃??ƒ?ÿ‘?ÿ‡?©‘?ý‘§?ƒ?¾ƒ?ª‡­¾‘??‡?æ‘«¸ƒ?©‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?Ï…ï©…ï?ƒï?‘??‡?ªƒ?ªÆ¬ðƒ?ªÆ¬î…ù?ƒ?ÿƒ?ÿ‘??‘¾Ý‘­œƒ?¾‘?œ‘ïÿ‡?¾‘?ü‘?õƒ?©‘¾?‡?ÿ‡?îƒ?ü‘û¾‡?¾‡?ÿ‘?©‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«?‘?ú†?ý‘?ù‘ñª‘?©‘?÷‘?ÿ‘û­ƒ?ü‘¾?‘?©‡?î…æüƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒñª‡?ÿŠ?ý‘¾Ý‘?÷ƒ?§‘?ªƒ?ü‘?ø‘?ýЏð‡?ï‡?¾‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?­‘?¾‡?ÿƒ?©‘¾ï‘?ýƒ?ïƒïùƒ?¸‡?¾…ù?ƒ?ÿƒ?ÿ‘«©ƒ?©‘?øƒ?ü‡?­‘?¾‡?ÿ‘?©‘?ÿ‡?­‘?ý‘¬ÿ‘ñ½‡?¸‘?æƒÿÿƒÏîƒ?©‘«?‡?æ‡?ÿ‡?î‘?ôƒ?§‡?æ‘ñ¸‡?¸‡?¾‡?ÿƒ?©‘¾ï‘?ýƒ?ï‡?î‡?ÿ‘?©‘?ÿ‡?­‘?ý‘¬ÿ‘ñ½‡?¸‘?æ‘?ÿ‘û­ƒ?ü‘柃ûχ­¾ƒû¾…ù?…ù?†­?„æ?„ñ?†??…ù?ƒ?ÿƒ?ÿ‘«?‘?ú†?ý‘?ù‘ñªƒïÿ†??‘«Ÿ‡?©‘ñî„?¾‘ñ¸ƒ?¾‡??†?ª‘?©„¾øƒû©‡??Æ?œ…ù?ƒ?ÿƒ?ÿ‘«?‘?ú†?ý‘?ù‘ñªƒïÿ‘?ô‡?ý‘«¸ƒ?©ƒ÷ýƒ?ø„÷ð„ñî‘?îƒ?î„Ïð‡?©‡?æ‘«?‘æý‡?­‡?ÿ‡­¾ƒ?ð‡?æ‡?ø„?ï‡?î‘?ðƒ?ï„æ?…æ?ƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ð„?ÿ‘æÏ‘û¸‘«?‘?ª…æüƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘æî‘?ð‘?©‡ªÿ‘??ƒæï‡??‘û¾„ñï‘?îƒïÿ‘«?„ûõ‘æ­ƒ?¾‘?ü‡?œ‘¾ý‡¾ï…櫃??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘æî‘?ð‘?©ƒ?ÿƒ?Ý„?¯‡?¾„?ð‘?ô‡?©‘«?ƒ?õ„øð‘?î‘??‘?ð‡?ÿ‘?¾‡?æ‡?¸‡æû…ï½…ï?ƒ??ƒ?ÿƒ?ÿ†?ÿ‡?îƒ?ý‡?æ‘ñ¸‡?¸‡?¾‘øÿƒ?¾‘?ø‘?ýЏð‡?ïƒ?¾„?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?υ遼??ƒ?ÿƒ?ÿ‘«œ‘æð‘û­ƒ?σ?«‘?õ‡?¸ƒ?ÿƸœ‡??‘«ý‡?õ‘æ­‘?ÿ‘ñ¸‡?¾ƒ?½…ïõƒ??ƒ?ÿƒ?ÿ‡¾½‘?ïƒ?üƒ?«†??‡?û‘?ïƒûð‘??‡?÷„?©‘?©‘?î‘û¸†æõÆù§‘û?‘?¸‘?îƒû¾‘??„?ï‡?û‡?¾ƒ?ù‘«œ‘æð‘û­ƒ¾Ï…ù?ƒ?ÿƒ?ÿ‘?Ï‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?σ?«„??‘ûî‘?ô‡?ýƸ?†?§„?î‡?­Æ?¾†?ï‡?ï‘û¸ƒ­õ‘?χ?û‡?¾…︃??ƒ?ÿ‡?ÿ‡?î‡?¾‘­ü‘ñ¾ƒûª‡­¾ƒ?¾‘?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?Ï‘?Ï‘?©‘?î‘?¾‘«Ÿ‘æð‘û­…æÏ„Ï?‡?ð‡?ü‘ñ½ƒ?¾‘?χ?ÿ‘?ý‡?¸‡?¾‘øÿƒ?­‘«œ‘æð‘û­‘?Ï‘?ÿƒ?©‘?ý‡?¸‘ûî‘?ÿ‡?õ‘?©‡?ÿ‘ñ­‡?¾ƒ?ý‘?χ?ÿ‡?­‘æ­‡??‘?ý‘Ïÿ‘?©‡?î‘?ý‡?œƒû¾ˆ÷ÿ‡?¨‡?÷ˆ¨¨‘÷ÿ‘?õ‡?ü‡?ÿ‡?­‡?ÿƒ?©‘«Ý‘æý‡?­‡?ÿ‘ñ­‘?¸ƒû¾„øÿ‡?¾‘?ÿ‡?î‘?ð‡?ï‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûî‹«ï…阮??‡­¾…æï†ÿ?„ñ?…ù?‘«?‘?©…ù?…ù?
Exit code:  3
- Debian 9.9
Avatar du membre
Mathieu
30 juil. 2019 - 17:52
je viens de voir que dans le setup d'origine il y avait deux lignes de ##
old_removed.extend(removed)
    WAPT.write_param(control.package,old_removed)
en supprimant les ## le packet s’installe avec un message a la fin
NoneTraceback (most recent call last):
  File "c:\windows\temp\wapthz_wv2\setup.py", line 96, in install
  File "C:\Program Files (x86)\wapt\lib\json\__init__.py", line 339, in loads
    return _default_decoder.decode(s)
  File "C:\Program Files (x86)\wapt\lib\json\decoder.py", line 364, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
TypeError: expected string or buffer
- Debian 9.9
raselinary
18 sept. 2019 - 16:45
J'ai en retour le message suivant et rien a été desinstallé!
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
"1527c705-839a-4832-9118-54d4Bd6a0c89", # (10.0.17763.1)",
"7EE7776C.LinkedInforWindows", # (2.0.1.0)",
"AppUp.IntelGraphicsControlPanel", # (3.1.0.0)",
"AppUp.IntelOptaneMemoryandStorageManagement", # (17.0.1011.0)",
"CyberLinkCorp.th.Power2GoforLenovo", # (8.0.8621.0)",
"CyberLinkCorp.th.PowerDVDforLenovo", # (14.1.8627.0)",
"E046963F.LenovoCompanion", # (4.26.43.0)",
"E2A4F912-2574-4A75-9BB0-0D023378592B", # (10.0.17763.1)",
"F46D4000-FD22-4DB4-AC8E-4E1DDDE828FE", # (10.0.17763.1)",
"InputApp", # (1000.17763.1.0)",
"Microsoft.AAD.BrokerPlugin", # (1000.17763.1.0)",
"Microsoft.AccountsControl", # (10.0.17763.1)",
"Microsoft.Advertising.Xaml", # (10.1804.2.0)",
"Microsoft.AsyncTextService", # (10.0.17763.1)",
"Microsoft.BingWeather", # (4.25.12127.0)",
"Microsoft.BioEnrollment", # (10.0.17763.1)",
"Microsoft.CredDialogHost", # (10.0.17763.1)",
"Microsoft.DesktopAppInstaller", # (1.0.22011.0)",
"Microsoft.ECApp", # (10.0.17763.1)",
"Microsoft.GetHelp", # (10.1706.10441.0)",
"Microsoft.Getstarted", # (6.13.11581.0)",
"Microsoft.HEIFImageExtension", # (1.0.11792.0)",
"Microsoft.HEVCVideoExtension", # (1.0.12203.0)",
"Microsoft.LockApp", # (10.0.17763.1)",
"Microsoft.MPEG2VideoExtension", # (1.0.6.0)",
"Microsoft.MSPaint", # (4.1807.12027.0)",
"Microsoft.Messaging", # (3.43.27001.0)",
"Microsoft.Microsoft3DViewer", # (4.1808.15012.0)",
"Microsoft.MicrosoftEdge", # (44.17763.1.0)",
"Microsoft.MicrosoftEdgeDevToolsClient", # (1000.17763.348.0)",
"Microsoft.MicrosoftOfficeHub", # (17.8918.5926.0)",
"Microsoft.MicrosoftSolitaireCollection", # (4.1.5252.0)",
"Microsoft.MicrosoftStickyNotes", # (2.0.13.0)",
"Microsoft.MixedReality.Portal", # (2000.18081.1242.0)",
"Microsoft.NET.Native.Framework.1.6", # (1.6.24903.0)",
"Microsoft.NET.Native.Framework.1.7", # (1.7.25531.0)",
"Microsoft.NET.Native.Runtime.1.6", # (1.6.24903.0)",
"Microsoft.NET.Native.Runtime.1.7", # (1.7.25531.0)",
"Microsoft.Office.Desktop", # (16040.10730.20103.0)",
"Microsoft.Office.OneNote", # (16001.10228.20003.0)",
"Microsoft.OneConnect", # (5.1807.1991.0)",
"Microsoft.PPIProjection", # (10.0.17763.1)",
"Microsoft.People", # (10.1805.1361.0)",
"Microsoft.Print3D", # (3.0.1521.0)",
"Microsoft.ScreenSketch", # (10.1806.2112.0)",
"Microsoft.Services.Store.Engagement", # (10.0.18101.0)",
"Microsoft.SkypeApp", # (14.26.95.0)",
"Microsoft.StorePurchaseApp", # (11805.1001.8.0)",
"Microsoft.VCLibs.110.00.UWPDesktop", # (11.0.61135.0)",
"Microsoft.VCLibs.140.00", # (14.0.26706.0)",
"Microsoft.VCLibs.140.00.UWPDesktop", # (14.0.26905.0)",
"Microsoft.VP9VideoExtensions", # (1.0.12342.0)",
"Microsoft.Wallet", # (2.2.18179.0)",
"Microsoft.WebMediaExtensions", # (1.0.12341.0)",
"Microsoft.WebpImageExtension", # (1.0.11551.0)",
"Microsoft.Win32WebViewHost", # (10.0.17763.1)",
"Microsoft.Windows.Apprep.ChxApp", # (1000.17763.1.0)",
"Microsoft.Windows.AssignedAccessLockApp", # (1000.17763.1.0)",
"Microsoft.Windows.CapturePicker", # (10.0.17763.1)",
"Microsoft.Windows.CloudExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.ContentDeliveryManager", # (10.0.17763.1)",
"Microsoft.Windows.Cortana", # (1.11.5.17763)",
"Microsoft.Windows.NarratorQuickStart", # (10.0.17763.1)",
"Microsoft.Windows.OOBENetworkCaptivePortal", # (10.0.17763.1)",
"Microsoft.Windows.OOBENetworkConnectionFlow", # (10.0.17763.1)",
"Microsoft.Windows.ParentalControls", # (1000.17763.1.0)",
"Microsoft.Windows.PeopleExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.Photos", # (2018.18051.21218.0)",
"Microsoft.Windows.PinningConfirmationDialog", # (1000.17763.1.0)",
"Microsoft.Windows.SecHealthUI", # (10.0.17763.1)",
"Microsoft.Windows.SecureAssessmentBrowser", # (10.0.17763.1)",
"Microsoft.Windows.ShellExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.XGpuEjectDialog", # (10.0.17763.1)",
"Microsoft.WindowsAlarms", # (10.1805.1361.0)",
"Microsoft.WindowsCalculator", # (10.1805.1201.0)",
"Microsoft.WindowsCamera", # (2018.425.120.0)",
"Microsoft.WindowsFeedbackHub", # (1.1805.2331.0)",
"Microsoft.WindowsMaps", # (5.1805.1431.0)",
"Microsoft.WindowsSoundRecorder", # (10.1805.1941.0)",
"Microsoft.WindowsStore", # (11805.1001.49.0)",
"Microsoft.Xbox.TCUI", # (1.11.28003.0)",
"Microsoft.XboxApp", # (41.41.18001.0)",
"Microsoft.XboxGameCallableUI", # (1000.17763.1.0)",
"Microsoft.XboxGameOverlay", # (1.32.17005.0)",
"Microsoft.XboxGamingOverlay", # (2.20.22001.0)",
"Microsoft.XboxIdentityProvider", # (12.44.20001.0)",
"Microsoft.XboxSpeechToTextOverlay", # (1.17.29001.0)",
"Microsoft.YourPhone", # (0.0.12084.0)",
"Microsoft.ZuneMusic", # (10.18052.20211.0)",
"Microsoft.ZuneVideo", # (10.18052.20211.0)",
"RealtekSemiconductorCorp.RealtekAudioControl", # (1.2.148.0)",
"Windows.CBSPreview", # (10.0.17763.1)",
"Windows.PrintDialog", # (6.2.1.0)",
"c5e2524a-ea46-4f67-841f-6a9465d9d515", # (10.0.17763.1)",
"microsoft.windowscommunicationsapps", # (17.9330.21365.0)",
"windows.immersivecontrolpanel", # (10.0.2.1000)",
Avatar du membre
Mathieu
25 sept. 2019 - 11:29
J'ai toujours une erreur sur le package j'ai plus de 100 postes qui sont en erreur
j'ai toujours le même message :
NoneTrying to remove Microsoft.MicrosoftOfficeHub
NoneTrying to remove Microsoft.MicrosoftSolitaireCollection
NoneTrying to remove Microsoft.OneConnect
NoneTrying to remove Microsoft.People
NoneTrying to remove Microsoft.WindowsAlarms
NoneTrying to remove Microsoft.WindowsMaps
NoneTrying to remove Microsoft.WindowsPhone
NoneTrying to remove Microsoft.WindowsSoundRecorder
NoneTrying to remove microsoft.windowscommunicationsapps
NoneTrying to remove Microsoft.MixedReality.PortalMicrosoft.BingFoodAndDrink
  File "c:\windows\temp\waptdzylcw\setup.py", line 98, in install
avez-vous une solution ?
- Debian 9.9
Avatar du membre
Gaetan
25 sept. 2019 - 15:08
est-ce que le script exécuté sur une des machines en erreur à la main fonctionne ?
Avatar du membre
Mathieu
25 sept. 2019 - 16:30
sur ma VM oui le paquet n'es plus en erreur alors que je n'ai fait aucune modification.
mais sur une autre machine lorsque je relance l'installation il est toujours en erreur
- Debian 9.9
