[SOLVED] mass forget package
empbilly
08 août 2018 - 14:13
I know that I can do this manually, but is there any way to select and have mass forgotten packets that are no longer part of the host?
Modifié en dernier par empbilly le 28 août 2018 - 16:59, modifié 1 fois.
empbilly
27 août 2018 - 13:15
Anyone have an idea if my question posted above is possible?
Avatar du membre
27 août 2018 - 14:30
Make a multi-selection of the target hosts (Ctrl+Click / UpperCase+Click) and make the focused one has the package you want to forget, then right click on the package / Forget.
empbilly
htouvet a écrit : 27 août 2018 - 14:30 Make a multi-selection of the target hosts (Ctrl+Click / UpperCase+Click) and make the focused one has the package you want to forget, then right click on the package / Forget.
Thanks htouvet!!! Works!!! :)
