[RESOLVED] wapt console via webGui
empbilly
22 mars 2018 - 12:24
Hi folks,
Is there any idea of wapt having a wapt console via webgui?
It would be amazing! :D
Dernière modification par empbilly le 23 mars 2018 - 14:55, modifié 1 fois.
22 mars 2018 - 12:39
For what use do you need a web console?
empbilly
22 mars 2018 - 12:50
sfonteneau a écrit : 22 mars 2018 - 12:39 For what use do you need a web console?
Centralized management!
22 mars 2018 - 14:49
Today, wapt can be launched from multiple console at the same time.
Each administrator can launch the console from his station.
empbilly
22 mars 2018 - 15:31
sfonteneau a écrit : 22 mars 2018 - 14:49 Today, wapt can be launched from multiple console at the same time.
Yes, we have already done so, but since we use linux, we need to have a VM for this. Not that a VM is the problem, but if it had a webgui, it would be more organized and better to manage. :D
22 mars 2018 - 18:00
wapt works fine under winehq :
https://www.winehq.org/
During installation, you must uncheck the installation of the service.
empbilly
22 mars 2018 - 19:07
sfonteneau a écrit : 22 mars 2018 - 18:00 wapt works fine under winehq :
Okay. I installed via playonlinux. Works! :D
vcardon
22 mars 2018 - 23:32
Happiness for all admins, that's the goal of WAPT ;)
Happiness for you first, then you can tell you friends.
Vincent
empbilly
23 mars 2018 - 14:56
Vincent CARDON a écrit : 22 mars 2018 - 23:32 Happiness for all admins, that's the goal of WAPT ;)
Vincent
Thanks Vincent!!! :D
