Erreur Migration WAPT 1.3 vers 1.5
tech62
12 déc. 2017 - 11:55
J'ai re-effectué un apt-get remove / update / clean / install, mais l'erreur est toujours présente.
J'utilise ce dépôt :
deb  https://wapt.tranquil.it/debian/wapt-1.5/ stretch main
Est-ce le bon dépôt ?
EDIT : Visiblement , c'est le bon
Préparation du dépaquetage de .../tis-waptserver_1.5.1.9-tisdeb9-4425-ef7b7b4b_amd64.deb
La version correspond à celle indiquée précédemment dans le topic (nighty build)
Mais l'erreur est toujours présente
2017-12-12T12:07:36.536+0100    connected to: 127.0.0.1
2017-12-12T12:07:36.603+0100    exported 6 records
WARNING:root:Traceback (most recent call last):
  File "/opt/wapt/waptserver/waptserver_model.py", line 424, in update_host_data
    existing = Hosts.select(Hosts.uuid, Hosts.computer_fqdn).where(Hosts.uuid == uuid).first()
  File "/opt/wapt/lib/site-packages/peewee.py", line 4941, in select
    query = SelectQuery(cls, *selection)
  File "/opt/wapt/lib/site-packages/peewee.py", line 3016, in __init__
    self.require_commit = self.database.commit_select
  File "/opt/wapt/lib/site-packages/peewee.py", line 439, in __getattr__
    raise AttributeError('Cannot use uninitialized Proxy.')
AttributeError: Cannot use uninitialized Proxy.
CRITICAL:root:Error updating data for [SECRET] : AttributeError: Cannot use uninitialized Proxy.
  File "/opt/wapt/waptserver/scripts/postconf.py", line 511, in <module>
    main()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 338, in main
    mongo_update_status = check_mongo2pgsql_upgrade_needed(waptserver_ini)
  File "/opt/wapt/waptserver/scripts/postconf.py", line 241, in check_mongo2pgsql_upgrade_needed
    run_verbose("sudo -u wapt /usr/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres")
  File "/opt/wapt/waptserver/scripts/postconf.py", line 68, in run_verbose
    output = subprocess.check_output(*args, shell=True, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 219, in check_output
subprocess.CalledProcessError: Command 'sudo -u wapt /usr/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres' returned non-zero exit status 1
tech62
13 déc. 2017 - 15:06
Up =)
tech62
14 déc. 2017 - 11:37
Réinstallation des paquets tentée avec la version mise à jour dans le dépôt
tis-waptXXX_1.5.1.10-tisdeb9-4448-a4bdc9c2
L'erreur a évoluée
2017-12-14T11:34:12.303+0100    connected to: 127.0.0.1
2017-12-14T11:34:12.390+0100    exported 6 records
    main()
upgrading data from mongodb to postgresql
could not change directory to "/root": Permission non accordée
dumping mongodb data in /tmp/waptupgrade_20171214-Dec:50:1513248632.json
Read mongo data from 127.0.0.1...
2017-12-14T11:50:32.872+0100    connected to: 127.0.0.1
2017-12-14T11:50:32.940+0100    exported 6 records
6 records read.
File /tmp/waptupgrade_20171214-Dec:50:1513248632.json done.
Loading /tmp/waptupgrade_20171214-Dec:50:1513248632.json
6 recs to load
{'computer_fqdn': u'nomachine', 'uuid': u'uuidmachine'}
  File "/opt/wapt/waptserver/waptserver_upgrade.py", line 154, in upgrade2postgres
    load_json(filenames=data_import_filename)
  File "/opt/wapt/waptserver/waptserver_upgrade.py", line 99, in load_json
    uuid = rec.get('uuid', rec['wmi']['Win32_ComputerSystemProduct']['UUID'])
KeyError: 'wmi'
Exception while loading data, please check current configuration
tech62
19 déc. 2017 - 10:21
Pas d'idée sur le problème ? UP !
Avatar du membre
19 déc. 2017 - 14:38
Je regarde
Le problème semble être ici :
Est t'il possible de votre coter de nous envoyer (en privé) le contenue de /var/lib/mongodb/
Stopper mongodb avant tout !
Vous pouvez l'envoyer a l'adresse sfonteneau@tranquil.it
Tranquil it systems
tech62
19 déc. 2017 - 14:48
Bonjour, merci du retour !
Où la base de donnée par défaut est-elle stockée ? (format json / bson / .db ?)
Edit : j'ai fais un mongodump ;)
Avatar du membre
19 déc. 2017 - 18:15
Bonsoir tech62,
le script que tu avais lancé et qui avait planté a du créer un fichier /tmp/waptupgrade_20171214-Dec:50:1513248632.json . Tu peux renvoyer ce fichier à Simon. Par contre il semble n'y avoir que 6 hosts dedans d'après les logs, c'est un serveur de tests? Sinon ça voudrait dire que l'export mongo n'a pas fonctionné non plus...
tech62
19 déc. 2017 - 18:21
Je regarde ca et vous fais un retour rapidement, pour les 6 postes c'est normal, je commençais seulement a intégrer le parc, c'est en voulant upgrader pour avoir la fonctionnalité liée au websocket (pour pouvoir déployer derrière un NAT) que ça c'est gâté :/
tech62
20 déc. 2017 - 12:12
J'ai refait hier soir un update / install et j'ai pu installer la version 1.5, seulement maintenant j'obtiens un code http 1.1/404 depuis la console d'administration, par contre j'arrive bien à supprimer / installer les paquets depuis le poste:8088
depuis l'adresse https://urlserveur/ping le résultat est positif en réseau interne comme en externe.
tech62
21 déc. 2017 - 17:33
Les dernieres releases du dépôt ont permis de faire la migration.
Reste maintenant ce bug
De mon côté dans un premier temps la vérification du certficat n'est pas active mais un wireshark me revèle que l'agent lors d'un wapt-get register éssaie de contacter :
_wapt-host._tcp.wapt.domaine.lan: type SRV, class IN
wapt-host.wapt.domaine.lan
wapt.wapt.domaine.lan
16:27:29.020990	DNS	192.168.1.1	53	192.168.1.101	59931	59931	59931	Standard query response 0xd256 No such name A wapt.wapt.domaine.lan SOA passerelle.domaine.lan	173
Mon fichier de config agent :
repo_url=https://wapt.domaine.lan/wapt
wapt_server=https://wapt.domain.lan
Les url ne concordant pas, l'agent me renvoie donc
C:\WINDOWS\system32>wapt-get register
FATAL ERROR : Exception: Wapt server url not defined or not found in DNS
Merci encore pour votre attention sur ce problème !
