Sur notre serveur WAPT, les services nginx saturent la ram (Memory: 10.6G (peak: 11.4G)), les processes nginx tombent.
Main PID: 1370 (nginx)
Tasks: 75 (limit: 100195)
CPU: 18min 11.549s
CGroup: /system.slice/nginx.service
├─ 1370 "nginx: master process /usr/sbin/nginx"
├─ 1891 "nginx: worker process is shutting down"
├─ 1895 "nginx: worker process is shutting down"
├─16158 "nginx: worker process is shutting down"
├─16160 "nginx: worker process is shutting down"
├─66534 "nginx: worker process is shutting down"
├─66536 "nginx: worker process is shutting down"
├─71634 "nginx: worker process"
├─71635 "nginx: worker process"
├─71636 "nginx: worker process"
├─71637 "nginx: worker process"
├─71638 "nginx: worker process"
├─71639 "nginx: worker process"
├─71641 "nginx: worker process"
└─71642 "nginx: worker process"
J'ai suivi les recommandations ci-après https://www.wapt.fr/fr/doc/wapt-server- ... ation.html.
La partition /var n'est pas saturée. Sur redhat, les dossiers nginx sont dans /var/lib/nginx/tmp/proxy/.
En complément :
curl http://127.0.0.1/nginx_status
Active connections: 1883
server accepts handled requests
129746 129746 133154
Reading: 0 Writing: 1880 Waiting: 3
Serveur Redhat 9.7
Wapt Entreprise 2.6.1.17765
Merci pour votre aide,
Yoni
