[RESOLU] Problème depuis MAJ 2.6.0.16881
TomTom
04 févr. 2025 - 09:06
Bonjour à tous,
Depuis ce matin je remarque une activité CPU anormale sur mes machines linux (ubuntu/debian).
Je viens de remarquer qu'elles ont installé la dernière MAJ de WAPT 2.6.0.16881 durant la nuit qui semble avoir une incidence sur le fonctionnement de l'agent.
Je mets en pièce jointe les captures d'écran de la conso avant/après arrêt du waptservice, la différence est flagrante. De plus, une capture de l'état dans la console.
Quand je tente un wapt-get upgrade sur les machines voici le retour :
Using config file: /opt/wapt/wapt-get.ini
Nothing to upgrade
2025-02-04 08:58:46,341 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:49,342 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:51,664 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:54,749 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:57,502 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:01,060 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:03,257 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:05,931 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:08,402 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:11,145 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:13,385 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:15,909 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
Merci de m'aider mon hôte commence à saturer :roll:
Thomas
Dernière modification par TomTom le 04 févr. 2025 - 11:32, modifié 1 fois.
Version de WAPT : 2.6.0.17392 (Enterprise Edition)
OS du serveur : Debian 12 "Bookworm"
OS de la machine d'administration/création des paquets : Windows 11 24h2
04 févr. 2025 - 09:18
Si le serveur n'a pas été mis à jour à la même version, cela peut être la source du problème.
Nous avions un problème chez un client dont les machines dans l'AD avaient un nom différent de leur hostname
On fait donc maintenant le matching (pour savoir si une machine a été clonée par exemple ou supprimée et nécessite d'être réenregistrée) sur le hostname seulement.
Malheureusement, le serveur à la version précédente ne renvoie pas ce computer_name et donc la machine se réenregistre (correctement) en boucle.
Avez-vous mis à jour le serveur ?
TomTom
04 févr. 2025 - 09:20
Non pas encore je ne voulais pas causer d'autre problèmes. Je vais le "snapshotter" et tenter la MAJ pour voir si comme vous le dites le problème pourrait venir de là.
Je reviens vers vous dès que j'ai plus d'infos
Merci pour la réponse rapide Hubert.
Dernière modification par TomTom le 04 févr. 2025 - 11:54, modifié 1 fois.
TomTom
04 févr. 2025 - 10:29
Effectivement le problème venait bel et bien de la différence de version client/serveur.
On peut clôturer tout est revenu à la normal.
Merci encore Hubert pour les explications.
