Hello everyone,
I would like to know if WAPT.options.force returns true or 1 when in the console we click on the package and we do a forced installation?
Thanks in advance.
[RESOLU] option WAPT.options.force in setup.py
In code :
Action is store_true, This should normally be a boolen
But normally in a package you just have to do "if force" in a package
parser.add_option("-f", "--force", dest="force", default=False, action='store_true', help="Force (default: %default)")But normally in a package you just have to do "if force" in a package
OlivierSchmitt
Thanks you are right, i have use "if force :"
Hi Olivier,
thanks for the update
, I'll close the topic.
