Erreur lors de l'installation de ['lso-vcredist2015-2022(=14.42.34433.0-28)']: erreurs dans les paquets [[PackageRequest(package='lso-vcredist2015-2022',version=(Version('14.42.34433.0'), 28),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('lso-vcredist2015-2022','14.42.34433.0-28' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptpj7e9g33\\setup.py", line 22, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3991, in run\n    return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2177, in run\n    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"VC_redist.x86.exe" /quiet /norestart /log c:\\\\temp\\\\vclog.log\' returned non-zero exit status 1603.\nOutput:\n']]
    self._run()
Exception: Erreur lors de l'installation de ['lso-vcredist2015-2022(=14.42.34433.0-28)']: erreurs dans les paquets [[PackageRequest(package='lso-vcredist2015-2022',version=(Version('14.42.34433.0'), 28),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('lso-vcredist2015-2022','14.42.34433.0-28' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptpj7e9g33\\setup.py", line 22, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3991, in run\n    return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2177, in run\n    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"VC_redist.x86.exe" /quiet /norestart /log c:\\\\temp\\\\vclog.log\' returned non-zero exit status 1603.\nOutput:\n']]
