j'étais sur WAPT 1.8.2.7393-75a5de09-debian-10-amd64, donc server debian 10. Je cherche à migrer vers la 2.4.0.14080
j'ai mis à jour debian vers la version 11, donc postgres 13 (database migrée à l'aide de pg_upgradecluster, tout s'est bien passé...)
J'ai suivi ensuite la procédure d'upgrade https://www.wapt.fr/en/doc/wapt-server-upgrade.html
Lors de l'étape post-install, j'obtiens:
root@host:~# sudo -u wapt /opt/wapt/bin/python -I /opt/wapt/waptserver/model.py upgrade-db -l info
initializing missing wapt tables without dropping data.
2023-08-06 17:21:57,559 INFO Connecting to waptdb explicitely. Count: 0
Unable to create tables, will try to upgrade step by step instead... : ProgrammingError('column "host_networking" does not exist\n')
2023-08-06 17:21:57,640 INFO Current DB: {'host': None, 'port': 5432, 'user': 'wapt', 'password': None} version: 1.9.0.4
2023-08-06 17:21:57,656 INFO Migrating from 1.9.0.4 to 1.9.0.12
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3144, in execute_sql
    cursor.execute(sql, params or ())
psycopg2.errors.UndefinedColumn: column t1.changelog does not exist
LINE 1: ...age", "t1"."icon_sha256sum", "t1"."is_available", "t1"."chan...
  File "/opt/wapt/waptserver/model.py", line 2784, in <module>
    init_db(False,server_config=conf)
  File "/opt/wapt/waptserver/model.py", line 2156, in init_db
    upgrade_db_structure(server_config=server_config)
  File "/opt/wapt/waptserver/model.py", line 2245, in upgrade_db_structure
    Packages.update_from_repo(r)
  File "/opt/wapt/waptserver/model.py", line 585, in update_from_repo
    (rec, _isnew) = cls.update_from_control(pe,is_available=True)
  File "/opt/wapt/waptserver/model.py", line 539, in update_from_control
    (rec, _isnew) = Packages.get_or_create(**key)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 6471, in get_or_create
    return query.get(), False
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 6884, in get
    return clone.execute(database)[0]
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 1907, in inner
    return method(self, database, *args, **kwargs)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 1978, in execute
    return self._execute(database)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 2150, in _execute
    cursor = database.execute(self)
  File "/opt/wapt/lib/python3.8/site-packages/playhouse/postgres_ext.py", line 490, in execute
    cursor = self.execute_sql(sql, params, commit=commit)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3151, in execute_sql
    self.commit()
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 2917, in __exit__
    reraise(new_type, new_type(exc_value, *exc_args), traceback)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 190, in reraise
    raise value.with_traceback(tb)
peewee.ProgrammingError: column t1.changelog does not exist
(A noter: je suis repassé sous WAPT 1.8.2 (sans downgrader Debian, donc toujours Debian 11) et tout marche sous cette version (j'ai quand même dû restaurer la base de donnée depuis une sauvegarde, la migration de DB du au post-install a dû s'arrêter au milieu du chemin... )
Une ideé?
Cordialement
