Hi i have an issue when trying to prepare a USB key for boot
I'm able to change the keyboard language, then choose the diskpart, after that i get this error on this Link: http://snpy.in/VmvWpP
Follow by a message like the usb are ready !
Issue using WinPE Usb Key\Bootsect.exe
Hello
Bootsect.exe is not present in system32
You are on a windows 7 ? I thought it was on all windows 10
I will see to add Bootsect.exe to the minimal wads-requierement package
juniormateus
Hi,sfonteneau a écrit : ↑10 mai 2022 - 13:07 Hello
yes it's on windows 10 also
You can try installing the tis-microsoft-adk package on your machine to see if it places this file?
juniormateus
Hi trying to download the package, here is the error in the link bellow:sfonteneau a écrit : ↑10 mai 2022 - 14:58 You can try installing the tis-microsoft-adk package on your machine to see if it places this file?
http://snpy.in/t5prcS
I got the wrong package name, it's "tis-adkwinpe"
juniormateus
I just updated the tis-wads-requirement-minimal package
https://luti.tranquil.it/get_folder_res ... 93aW5kb3dz
it now includes the copy of the Bootsect.exe file if it is not present on your machine
you can duplicate the package from this repository : https://wapt.tranquil.it/wapt-testing/
juniormateus
Thank You let me tested, and i will let you knowsfonteneau a écrit : ↑11 mai 2022 - 13:51 I just updated the tis-wads-requirement-minimal package
juniormateus
I got this error, when try to duplicatejuniormateus a écrit : ↑11 mai 2022 - 16:01Thank You let me tested, and i will let you knowsfonteneau a écrit : ↑11 mai 2022 - 13:51 I just updated the tis-wads-requirement-minimal package
http://snpy.in/3Qlvvk
